Home > Maintenance & Mods (L322) > Towing Mirrors
Page 1 of 3 123>
Trantorman
United Kingdom 2017 Range Rover Vogue SE SDV8 Aleutian Silver
Towing Mirrors
Looking for some advice from the Tin shed draggers...
I have a new Brain James RS6 enclosed transporter which will be towed behind my TDV8, its just over 8 feet wide, so looking for some current advice on the best extension mirrors to buy and the best place to buy them from?
Many Thanks
Post #375085 1st Mar 2016 12:32pm
I tow a boat that is 8.5 feet wide (102"), though clearly a different shape.
I found the mirrors on the FFRR perfectly adequate for the job - but when I took it on a long run I did fit some Milenco mirrors more for the sake of appearance & to be 100% sure to comply with any laws as I drove through Germany & France.
I didn't find the towing mirrors particularly helpful - if anything slightly distracting as they had a small amount of vibration - it was the shaky image that was distracting.
I picked mine up of eBay
Post #375086 1st Mar 2016 12:47pm
mzplcg
Milenco Aero 2. Work fine. I added a 3rd clamp to each one to help with stability. Stay away from the grand aeros as they're bigger than is practical.
Post #375088 1st Mar 2016 1:21pm
Probably where I went wrong - I had Grand Aeros Thumbs Up
I've since re-sold them on eBay for what I paid for them - the boat only does very local trips these days
Post #375091 1st Mar 2016 3:10pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
i use the suck it and see type with a convex one on the near side. Never fallen off but have a little safety strap on anyway, advantage is they adjust with the mirrors
I think mirrors are a legal requirement despite the width of the FF Mine was a blue one! Smile
Post #375096 1st Mar 2016 3:59pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
I have the large milenco mirrors for towing my large caravan. I have tried the stick mirrors but they slipped and occasionally fell off.
http://www.milenco.com/products/mirrors/mi...ng-mirror/
Be ware that although you can see behind quite well when towing without mirrors in a Range Rover, it's the law that you have to have mirror extenders.
Post #375108 1st Mar 2016 5:20pm
miggit
I use a set of these, Whistle I wouldn't tow without them ....
They are Smat Weekender Towing Mirrors, unfortunately they are no long available new as they have stopped making them Sad But you still see them on Ebay.... I got a spare mint set for under £15 delivered last year Thumbs Up They are a lot more stable that the clamp on mirrors and they don't place unnecessary strain on the mirror motors
Don't worry if the rubber strap is broken as these can be replaced by a bungee strap, and because I use mine day in and day out I put some static cling vinyl (like the dealer signs in the rear window) under the pads to save the paint Thumbs Up
These are the wing mount http://www.ebay.co.uk/itm/Caravan-Towing-M...Swll1W0qXu
And these are just the ticket Thumbs Up http://www.ebay.co.uk/itm/towing-mirrors-/...SwFqJWs8hV
And this will save the paint http://www.ebay.co.uk/itm/A4-1mtr-Rolls-Of...CiMLjg1z0g
An A4 chunk will make 4 paint savers Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #375117 1st Mar 2016 5:54pm
Not true Razz
In the UK, the law is complex & vague - you need to have an adequate view behind you - which is generally interpreted as you need to be able to see 20m back & 4m either side - so it's all about the angles & length of the trailer.
You don't explicitly need extended mirrors.
It's probably quite complicated maths, but fairly straight forward to test.
In Europe it may well be different.
Post #375119 1st Mar 2016 5:57pm
Probably illegal now Whistle It's an offence to have anything protruding more than 200mm from the vehicle or trailer - whichever is wider - so with a wide trailer you might be OK
I would guess that you can't buy anything which would typically be more than 200mm wider than the car just to be on the safe side.
250mm for post 2007 cars Confused
Post #375124 1st Mar 2016 6:15pm
Trantorman
All Many Thanks
Miggit,
well done all bought, so will start with them and keep and eye out for some
Milenco Aero 2
Post #375131 1st Mar 2016 6:51pm
miggit
Thumbs Up They are the best mirrors that I've used..... and they are adjustable in width, Alistair, Ner Ner And every thing that I tow is 8 foot wide, and 10 foot high Shocked Shocked
They clip on to the window ledge and the door bottom, I'll post some installed pics tomorrow, as they can be a bit of a head scratcher Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #375134 1st Mar 2016 6:59pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Not true!
When did they alter that rule?
Only gave up caravaning 2 years ago. AFAIK it was always law you had extended mirrors, and tbh I wouldn't tow without them.
Greg.
Post #375161 1st Mar 2016 8:16pm
It's never been the law - just an interpretation - probably true for 99% of cars with caravans given the dimensions ,but the law is just that you need adequate visibility.
I've never actually towed a caravan, but did look into it extensively at one point.
Post #375174 1st Mar 2016 8:52pm
Buz1500
This may assist.
https://www.lifesure.co.uk/blog/2013/06/ca...w-the-law/
Post #375175 1st Mar 2016 8:57pm
Still not entirely accurate - it's the width of the mirror, not the rear of the car that matters, but close enough I suppose.
https://www.gov.uk/towing-with-car/towing-equipment Thumbs Up
However, it would seem that all 'standard' caravans would require extended mirrors - at least they did the Milenco were caused of misleading advertising which is probably where the confusion stems from Whistle
http://www.milenco.com/products/mirrors/news/
Post #375177 1st Mar 2016 8:59pm
Page 1 of 3 123>
