Home > Maintenance & Mods (L322) > How clean should oil look after a service?
rar110
I just had a service on my tdv8 L322. It's almost at 250,000km. I checked the oil after a short tip home. This is what it looked like and I'm wondering whether the didn't drain the oil from both sump plugs or forgot to change the filter. Here's a pic after the drive home:
What do you think. ______________________________
Post #378087 17th Mar 2016 11:15pm
sako243
I suspect that will always be the case. I'd imagine you'd have to strip down the engine to clean it thoroughly.
Bear in mind that diesels are also pretty high pressure so there's more of a chance of stuff slipping past the piston rings.
If it helps mine was similar... Ed
Post #378088 17th Mar 2016 11:23pm
Rule of thumb rar110 drip the engine oil onto your finger, then put your two fingers together as if you are checking the viscosity... If it stains your fingers and does NOT wipe off your finger using a tissue, then the oil is dirty/old... If you need swarfega to clean it off Rolling Eyes
Post #378104 18th Mar 2016 12:21am
rar110
Thanks for the replies. I should clarify that I'm quite satisfied the oil was changed. I'm mainly concerned whether both sump plugs were drained.
While I'm at it, does this look new:
Post #378106 18th Mar 2016 12:29am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
That air filter looks far from new, look deep into the folds for dirt and debris to confirm. It should be uniform colour with no blemishes. I have limited experience with Diesels, just done my 3rd oil change on my TD6 and already know the new oil looks dirty after very few miles. Cam-Tech-Craig`s tip is one to remember Thumbs Up . 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #378114 18th Mar 2016 2:33am
Road Stone
Hi Rar110,
I'm changing my filter this weekend and will post a piccie of it. 5000klms old during the dry so expecting it to be dusty.
Cheers, Jerry
Post #378117 18th Mar 2016 6:16am
rar110
Ta Jerry.
I ended up taking out the whole filter box to clean it out. There was leaves and sand in there. It's interesting that it's only really held in place by 3 pins into rubber grommets, the inlet tube going into the side panel and the two outlet tubes.
Another interesting feature is a factory hole in the inner side panel that looks to be for a snorkel or RAI. Pic below.
Post #378118 18th Mar 2016 7:24am
rar110
The hole has a plastic cap fitted. It doesn't look very big in the pic but I think it could be 65-75mm diameter. I should have measured it. ______________________________
Post #378119 18th Mar 2016 7:29am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Just my pennies worth , I get my oil changed during a service at every 7'- 10 thousand kms and it does look pretty clean at each change , the mechanic didn't change cabin filter last time because it's spotless , he's a BMW specialist and was surprised how clean the oil was himself 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #378122 18th Mar 2016 8:36am
rar110
I pulled the air filter out and it's clean and new. ______________________________
Post #378156 18th Mar 2016 1:24pm
Road Stone
My new filter against old. The replaced filter is 4300klms old.
Cheers, Jerry
Post #378420 20th Mar 2016 6:29am
rar110
I think you need a snorkel Jerry. Alternatively, keep a spare filter for trips away. I'll try to remember to take pics of mine after 4-5000km to compare with mine which does mostly city driving. Also, I'm heading out to Lightening Ridge for a trip soon. I take pics after that. It's mostly bitumen but can be dusty. ______________________________
Post #378585 20th Mar 2016 11:13pm
Road Stone
Hi rar110
Snorkel would be great but I dont think you can get one for these without a lot of mucking around!
Who do you use in Brissie, Indies are few and far between and you have to travel some distance.
Envious of Lightning Ridge, and yes please do post pics of the filter after that trip.
Cheers, Jerry
Post #378606 21st Mar 2016 7:30am
rar110
Gday Jerry
Three Brissie indies I've used are MR Automotive Redcliffe, Knights Albion and Greg Tungstall Ormiston. I would happily give my L322 to any of these. ______________________________
Post #378795 21st Mar 2016 10:58pm
