Home > Maintenance & Mods (L322) > Error codes
Declan303
Ireland 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Error codes
Hi all,
Now that a new batch of us have IID tools, is there a definitive list of codes anywhere to help with figuring out what all this stuff means. I cleared the lot the other day and checked a couple of times since. Each time, there appears a few new ones which clears with the exception of one which pops back up immediately after clearing.
IP-Instrument Pack
• 0xBD EBV function fault received from ABS ECU
I also got these two last time I checked, but I'm sure will probably clear ok
PATS-AntiTheft
• 0x3 Key 0 - Random code tolerance increased
ATC-Heat / Cool
• 0x30 Air quality sensor line fault
Is this normal to see random codes like this that just clear or should this be clean all the time?
Oh! just to mention, any codes I've seen don't appear to cause problems as car is driving perfect and everything working
Declan Declan
2003 FFRR Vogue 4.4 V8
97 Defender 90 300 TDi
Post #378604 21st Mar 2016 7:02am
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Hi There,
You are not alone, I too get a random code P065E. Says something to do with manifold but on further investigation could be the MAF setting this off. I have found a broken wire to the MAF! Like you car runs well.
As you say they are difficult to work out as something totally unrelated can set one off.
Cheers, Jerry
Post #378605 21st Mar 2016 7:24am
Declan303
When I put the IID on for the first time the other day when I got it, I think there was about 20+ codes sitting there. Think I hit the wrong button by accident and cleared the lot Whistle Declan
Post #378607 21st Mar 2016 7:34am
boatsandy1966
United Kingdom 2004 Range Rover Vogue SE Td6 Adriatic Blue
hi Declan how are you finding the obd tool I haven't got around to having a guy yet with mine hope to later this week I'm hoping to be able to program so windows and roof closes when locking 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #378609 21st Mar 2016 7:37am
Declan303
Just plodding my way around at the moment. Haven't gone mad yet and made any changes Very Happy Very Happy. Mostly interested in the codes that I see each time I have tried it and wondering is that normal. Question Question Declan
Post #378610 21st Mar 2016 7:41am
boatsandy1966
lol I have a code reader that I use on my daughters Peugeot must admit that sometimes a code shows up car runs ok then after looking up code plug in reader again and its gone am looking forward to seeing if I have any codes stored good luck ! 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #378611 21st Mar 2016 7:45am
You can safely ignore the first two, they will just come back if you clear them, and do not impact on the car (as per GAP info).
The third one could be the sensor in behind the vent in the dash, or it is the sensor attached to the top of the radiator. I have always had this code too, but doesn't seem to affect anything else. .
Post #378728 21st Mar 2016 7:37pm
Yep, as Joe says, those three seem to be pretty standard, seen them on every early one I've plugged in (bar one, that didn't have any of them...weird)
The old codes you cleared are meaningless... the main dealers don't bother to clear codes when they repair FF's so the codes could have been from when the car was a week old...
You did the right thing.... clear all the codes and see what comes back... then ignore them... Whistle Whistle
The best thing you can do is go through all the live data fields and make a note of the settings each one is at when you haven't got a problem, this will help if/when you do get one... Using your phone to video you going through them saves a lot of writing... Thumbs Up Thumbs Up Pete
Post #378736 21st Mar 2016 7:57pm
Declan303
Thanks for info Thumbs Up When you say "as per GAP info", where did you find the descriptions of the error codes? Declan
Post #378738 21st Mar 2016 8:01pm
Declan303
Thanks Pete,
Will do that and get some logs of the live data. Not really worried about those codes as I say, car is running perfect so not going to try and fix what is not broken, Very Happy . Just surprised though on googling that code about the abs, could not find anything, so question is, where does one get info on these codes if it was needed.
Declan Declan
Post #378741 21st Mar 2016 8:07pm
Got the info by asking Patrick at GAP via email .
Post #378806 21st Mar 2016 11:51pm
From the email:
Quote:
BD EBV Function Fault Received from ABS ECU (this came straight back after clearing all faults). We’ve seen this fault on other vehicles also. It may disappear after a while (when a clear fault is done of course). Check your ABS ECU’s fault to see if there is something in there, if not, leave it alone.
Quote:
23-Key 2 random code tolerance increased (no problems with my only key) We’ve seen many RR with this errors including our 2005, nothing to worry about.
Thumbs Up .
Post #378913 22nd Mar 2016 6:47pm
