Home > Technical (L322) > Is there a better diesel to use?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
My 2003 TD6 only does about 2000 miles a year (she's done 107k now from new), so filling her up isnt done that often, so i dont mind putting the best/cleanest diesel into her, is there a preferred diesel to use?
I run injector cleaner through her regularly but was wondering what you'd put in yours if it all cost the same?
Cheers guys
Post #380223 31st Mar 2016 7:36pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
BP Ultimate, if it all cost the same.
It is the only one out of all I have tried (Excellium, V-power,etc) that works. Defiantly noticed a difference whilst towing the tin tent with our old chipped P38.
I use it now and again to give the system a good clean out.
10-15 pence a litre more than standard diesel.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #380232 31st Mar 2016 8:35pm
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
I run my TDV8 on BP Ultimate as well, no issues so far. Thankfully I only spend £30 a month on fuel, so cost isn't a worry.
Post #380239 31st Mar 2016 9:02pm
Re: Is there a better diesel to use?
Don't do it too much, you won't do it any favours.... every 10,000 miles is plenty.... Thumbs Up Pete
Post #380243 31st Mar 2016 9:16pm
Rangeyman
If you only do 2000 miles why did you not buy the petrol ?
Post #380251 31st Mar 2016 9:50pm
Digger7820
United Kingdom 2002 Range Rover Vogue Td6 Rimini Red
Try putting some 2 stroke oil in the occasional tank will not do any harm and will lube top end Thumbs Up Range Rover vogue Td6
Land Rover Defender TD5
Grand Jeep Cherokee
Discovery 300tdi
Discovery 200tdi
Series lll short wheel base
Super 7 kit car
AC Cobra (still got)
Post #380279 1st Apr 2016 12:00am
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
I found that the tesco diesel affects mine in cold weather when you first start it up it doesn't sound like it's firing on all cylinders for the first 30secs then runs fine I changed it to ultimate and it ran perfect on start up and felt a bit nippier (maybe placebo ) L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #380281 1st Apr 2016 12:19am
pld118
mrblonde wrote:
... was wondering what you'd put in yours if it all cost the same?
These threads might interest you Mr Bl Thumbs Up
Branded v Supermarket fuel
http://www.fullfatrr.com/forum/topic22856-60.html
Best fuel cleaner?
http://www.fullfatrr.com/forum/topic30391....arket+fuel
Post #380285 1st Apr 2016 5:34am
