Home > Technical (L322) > engine starts only with gear in neutral position ? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Welcome aboard!
17th Apr 2016 8:01pm |
gillech Member Since: 03 Nov 2015 Location: montreux Posts: 18 |
thanks for your help.
17th Apr 2016 9:29pm |
There are a thousand things that could cause "Trans Failsafe Mode" but yours is clearly related to the gearshift!
18th Apr 2016 12:43am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3654 |
I got this message a couple of times on my old car cleaned and greased the selector rod - problem solved Geoff |
18th Apr 2016 7:21am |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 |
It would be worth checking the alignment of the shift cable. If the selector position doesn't match what the the transmission is seeing it could cause many of these faults.
18th Apr 2016 8:27am |
And lubricate the above.... |
18th Apr 2016 8:32am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
+1 ^ The shift cable is out of adjustment at the gearbox end and lubricate. |
18th Apr 2016 9:43am |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
I have had similar on a non-RR.
18th Apr 2016 10:04am |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 |
Check your Inhibitor Switch or XYZ switch.Im on my second one and the symptoms are exactly as yours. |
19th Apr 2016 10:24am |
thank you Rathbran,
19th Apr 2016 12:31pm |
It "inhibits" you or stops you from starting the vehicle in gear on an automatic gearbox.If you look underneath the vehicle at the gearbox you will see it and how exposed it is to the elements.Mine just went bad after approx 6-7 years and I have put a second one in .Its not too bad of a job and you can see the instructions in the online manuals in the wiki
19th Apr 2016 12:57pm |
