Home > Technical (L322) > Rear camber |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1662 |
On the face of that picture it does look out (by a long way) but pictures can be deceiving.
18th Apr 2016 1:49pm |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 |
That looks wrong.did you hit a rut or something recently to knock the alignment out.Either that or your upper hub bushes/camber bolts are on their way out...garage time again |
19th Apr 2016 10:28am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34931 |
loks like you are parked sideways on a slope..it could be low pressure in the tyre which with its high sidewall gives you that appearance.. ... - .- -.
19th Apr 2016 10:48am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I had mine 4 wheel tracked at Kwik fit which was pretty extensive and the tracking and camber can all be adjusted provided your bolts are not seized solid inside the bushes on the inner track control arm or outer hub. A common fault is the upper and lower hub bushes that I changed on mine along with the track control arm and all relevant adjusters and bolts.
19th Apr 2016 10:11pm |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Just a thought ..
20th Apr 2016 9:55am |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 |
No, it's at normal height with the engine running.
21st Apr 2016 7:33pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Comparing it to the front wheel I'd say it's got quite a lot of camber on it. Ed |
21st Apr 2016 9:04pm |
I wonder if it's exaggerated by the 32" tires.
24th Apr 2016 10:11am |
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 |
G'day Chex,
25th Apr 2016 7:01am |
im going into town in a couple weeks to have it checked and change bushes (i have a full set lying in my store for some time now) 2004 L322 V8 |
25th Apr 2016 7:10am |
