Home > Maintenance & Mods (L322) > 06 TD6 Air con |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3969 |
Have you checked the outlet air temperature at one of the face vents with the ac on. Give it time for the system to cool
22nd Apr 2016 5:19pm |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
Sadly yes - it was no cooler than ambient (15C ish) but I'm used to the 4C chill! |
22nd Apr 2016 7:50pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
That does rather sound as if the compressor isn't compressing.... if the centre of the compressor is turning, then you should be getting a drop in the temp..... sounds like you might need to seek a specialists help.... although I did come across a similar thing, and that turned out to be an over charged system.... it overheated almost instantly and caused the electric fan in front of the rads to be on continuously, and the ally pipe at the top left corner of the rad got stupidly hot Yesterday I couldn't spell Engineer... Today I are one!
22nd Apr 2016 11:12pm |
I'm confused (admittedly not very difficult...).
24th Apr 2016 3:25pm |
Fixed ...
25th Apr 2016 2:09pm |
That'll teach you to trust a tyre fitter with your Air Con
25th Apr 2016 2:55pm |
guilty as charged (A different branch 3 years ago were very good and I had hoped that the automated machines would remove most of the operator error...) ! Thanks for your help |
25th Apr 2016 3:09pm |
