Home > Technical (L322) > Suspension Height Sensor confusion |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I don't know is the honest answer but I use the Russian microcat site that shows what part numbers you need depending on chassis number and if you have the early l322 with xenons you will have the troublesome headlight levelling ECU sitting in a puddle in your passenger foot well.
26th Apr 2016 10:41pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 559 |
Speak to Dan @ Duckworths - he will advise on the right part number for your model based on the chassis number. Current Fleet:-
27th Apr 2016 8:18pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7916 |
Just had all this....
27th Apr 2016 8:26pm |
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 |
order the cheap one
27th Apr 2016 9:08pm |
Got the cheap one that's supposed to be OK for cars with zenons, fitted it yesterday and it does not work . the BMW diagnostics show at full height it reads + 1 volt and at its lowest setting it reads0.6 volts the others read between 4.5 and1.5 volts . this may be down to it being a Brit part one but not convinced that is not down to it not being the right one for zenons. luckily the arm was the only thing that was broke on the old one so out of the 2 I was able to make a good one |
1st May 2016 5:11pm |
Had bad height and ABS sensors from Britpart, don't bother any more.... genuine or OE only...
1st May 2016 5:42pm |
