Home > Technical (L322) > 6hp26 transmission/transfer slipped into neutral |
I'd first check if the selector cable and mechanism are in good shape. Wouldn't surprise me if something came loose not being tighted properly when the work was done and the selector is actually pulling it into neutral or keeping it on the edge.
27th Apr 2016 6:07am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Thanks mate. I'll have a look on the weekend. I assume they relearned the transmission.
27th Apr 2016 8:12am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
+1 for selector linkage , mine did the same once . cleaned it all up and sprayed with good silicone grease and good as gold since . Always go for the simple and obvious before you need to panic 2008 MY Supercharged
27th Apr 2016 8:48am |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 29 |
I would also check the transmission fluid level. |
27th Apr 2016 12:06pm |
Thanks again for the replies. Should I be checking cable connections at the selector or transmission end? ______________________________
27th Apr 2016 11:12pm |
I'd start at the gearbox end first as that is the part that has been loose. Also have a good look around to see if the cable is free, check if the wiring connector is also seated properly, just to be sure.
28th Apr 2016 2:46am |
