Home > Technical (L322) > Oil change problems. |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 118 |
Hi Folks.
26th Apr 2016 8:16am |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
there are 2.
26th Apr 2016 9:24am |
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 |
Next time you change your oil .
26th Apr 2016 9:25am |
Thanks folks. I think I will be changing my Indi. |
26th Apr 2016 9:45am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
How can he call himself an indy ???
26th Apr 2016 4:24pm |
The sump plugs should be changed on each service. My worry would be the stripped thread? I would get it to a specialist pretty quick. |
26th Apr 2016 4:51pm |
No he didn't have to say anything however he also told me what a massive job it is to change the sump due to having to remove the driveshafts etc. I was more worried about the fact they didn't know it had 2 drain plugs to be honest as I try to keep up with things. The last 2 oil changes have been done incorrectly now as far as I'm concerned. Very annoying! |
26th Apr 2016 5:00pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Not the same engine but my sump plug thread is on it's way out so I have a helicoil kit and new bolt on standby for the next time I change my oil which would save the sump removal if done carefully. |
26th Apr 2016 10:50pm |
Yes I think that will be my plan, what size did you get? |
27th Apr 2016 6:29am |
Try to find out which part is missing threads. If it is the plug, they can be replaced but if it is the oil pan, then a helicoil should do the trick. Get someone who knows how to do a helicoil properly though !!!! MY 2010 5.0 SC Galway green and sand interior!!
27th Apr 2016 8:07am |
Yes it's the pan unfortunately. |
27th Apr 2016 12:31pm |
This is similar to the one i purchased. My engine is the 4.4 V8 petrol M62 BMW engine 2004 http://www.ebay.co.uk/itm/M12-X-1-5-X-16-3...Sw5ZBWMjzt |
27th Apr 2016 6:52pm |
Thanks mate |
29th Apr 2016 1:35pm |
That is likely to be a different size to what you need though |
29th Apr 2016 5:47pm |
