Home > Technical (L322) > Restricted Performance 4.4 tdV8. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
Does it have the updated secondary turbo drain fitted? If not then it may have been accumulating oil in the secondary inlet tract. A stuck change-over valve doesn't cause lots of smoke but will cause restricted performance. |
22nd Apr 2016 1:17pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3676 |
No, I don't think the turbo drain mod has been done.
22nd Apr 2016 3:27pm |
do you drive mostly under 2000 rpm?
22nd Apr 2016 4:43pm |
You will know 1500 RPM is over 80mph in D, so I will have to start manually selecting 4th gear to see how it goes?
22nd Apr 2016 5:04pm |
Don't need to run at 2500 all the time, but there is so much torque available that with a less than heavy foot its possible to never use the second turbo.
22nd Apr 2016 5:26pm |
Thanks Nmj, I think you have explained the sequence , and put my mind at rest.
22nd Apr 2016 6:25pm |
30th Apr 2016 5:27pm |
Are you able to post the whole LTB?
30th Apr 2016 9:23pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
Forgive my ignorance but is a stuck change over valve as a result of the oil drain pipe issue or separate?
1st May 2016 11:36am |
2 loosely-coupled problems that can occur if the secondary turbo is rarely used. The oil accumulates from the unused turbo and the valve's linkage can become sticky from dirt/grit getting into the joint to the extent that it doesn't move freely if not used frequently enough.
1st May 2016 12:08pm |
I have been told that the modified operating arm moves much more as the 2nd turbo fires up .
1st May 2016 3:12pm |
