Home > Technical (L322) > 2004 L322 making vibration sound between 50-65mph?
Knightrider
Hi guys as per the title my 2004 ffrr that I have owned for over 2 years makes a vibration sound under acceleration. It doesn't always make the sound but when it does it tends to be between 50 - 65mph, after that it's silent and smooth again. I have also noticed that if I take my foot off the accelerator while it's making the noise that the vibration stops instantly.
Does anyone have any idea what is likely the cause of this and what I would need to do to put it right? It's been doing this to over a year at least and doesn't seem to have gotten any worse or noisier. Everything else on the car works perfectly.
I'm based in warwickshire can anyone recommend a honest and competent specialist to do any work required?
Thanks in advance for any help. 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #384877 2nd May 2016 2:06pm
Dolphinboy
Torque converter on its way out?
Post #384961 2nd May 2016 10:56pm
^ +1... Sounds like the TC to me too
Post #384963 2nd May 2016 11:14pm
Knightrider
Hi thanks for the replies, if it's the Torque Converter what is the implication of not changing it till it fails completely - will that mean it damages the gearbox or will it just mean the torque converter needs replacement? Does anyone know how much I should be paying for the part and labour for replacing it? 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #384978 2nd May 2016 11:50pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
That noise is caused by the lockup clutch failing when it's trying to engage to lock the input shaft to the TC and breaking up. I had the same thing a couple of years ago, should be around £700 for a new TC and fitting. I decided to have the gearbox refurbished at the same time as they had to take it out anyway to fit the TC so was round £1200-1300 from what I can remember. Took about 4 or 5 days to get it done.
Leaving it is one of those things, you know it's broken but it's really how far you want to push a faulty part with the possibility of when it does finally give up what else it takes with it and how stranded it will leave you. I would recommend getting it done as soon as possible.
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner
Post #384997 3rd May 2016 8:28am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
If the TC is starting to fail it will be burning/breaking up the lockup clutch lining.
The addition of the bits of clutch to the transmission fluid will eventually cause excessive wear in the gearbox and take that out too.
I'm surprised that it has already lasted a year like this...
A specialist can strip the TC and replace the clutch rather than simply replace the TC.
All transmission fluid will need to be changed as well
Post #385039 3rd May 2016 11:20am
Knightrider
Does anyone know any decent transmission specialists in the warwickshire/midlands area that they can recommend to do the work or is this something any competent mechanic can do without any special tools or software? 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #385049 3rd May 2016 12:04pm
