Home > Technical (L322) > Tiny Fan in HEVAC panel ..... Highly likely the culprit! |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 |
Like you I've had this problem since buying it 2 years ago. I'm about to start reconnecting everything I disconnected trying to find the problem - mirrors, CD player, satnav (although satnav useless anyway as cd sticks). If I could just sort out the hot start issue I might even stop considering selling it Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
28th Jun 2016 11:17am |
Elduke Member Since: 22 Apr 2013 Location: Glasgow Posts: 148 |
A good excuse to upgrade to a mk 4 sat nav unit if you can find one at a reasonable price |
28th Jun 2016 11:27am |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 719 |
I had a fair few issues with battery drain over the years on my 2003 TD6, main one being the FSR (she's on her 3rd one in 7 years), also had a drain from the headlight wiper relay (cant remember the number) and also one from the BCU. There's a thread I started on here ages ago somewhere about it, but solved the headlight wiper issue by pulling the fuse and since replacing the FSR again, the battery doesn't drain like it used to (he says... famous last words). |
30th Jun 2016 7:38am |
I changed my FSR early on as that seemed to be a common problem (however I wasn't having any problem with the fan either before or after). I pulled the fuse for headlight wipers and removed them as the previous owner had put the wrong grill on which didn't allow them to park (still yet to put better grill on). I also disconnected mirrors as one was playing up - just in case it was that, tv tuner (that had also gone wrong), cd changer in case it was that!!!! Really hoping I've finally found the culprit Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
30th Jun 2016 7:49am |
