Home > Technical (L322) > Fault code P0401-20 |
Jones S13 Member Since: 16 Jul 2016 Location: birmingham Posts: 8 |
What code reader were you using? wording seems strange. I'm sure that code relates to EGR insufficient flow (because it is blanked) not so sure on the L322 but I know from experience on BMWs when blanking the EGR it needs to be 'written out' of the ecu. Or you can drill a small hole in the blanking plate to let a small amount of gas through so it can 'see' EGR flow. Personally I'd have it mapped. |
17th Jul 2016 10:05pm |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 324 |
Hi Jones S13,
18th Jul 2016 7:09am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
The egr on the td6 is vacuum operated. When you blank it off, blank /block the vacuum hose. Job done.
18th Jul 2016 1:44pm |
Thanks Wayne. |
18th Jul 2016 10:34pm |
Found leak in top hose that comes from intercooler steel pipe to inlet manifold.
19th Jul 2016 4:11am |
I am sure someone on AULRO recently found a silicone substitute in Supercheap or Repco. Maybe ask there, I cant as I dont pay.
19th Jul 2016 4:30am |
