Home > Technical (L322) > Odd wiper behaviour |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7949 |
Rangeroveritus, a very common complaint... if it doesn't work now a switch off or battery reset usually works... premature alopecia happens if you try to define WHY..... Pete
1st Aug 2016 10:27pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
I suspect it's because I was just telling my son's friend all the things I'd done to it, and that it was mostly sorted! Probably just to let me know to stay on my toes
1st Aug 2016 10:57pm |
I find this the best LPG map....
1st Aug 2016 11:27pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1348 |
The wipers on my 2004 car developed an intermittent fault like that. I think it is quite a common problem and there will be threads about it on here. Relay failure is often the cause, in my case it was something else, I can't now remember, but not expensive to fix. Better to check it out than assume it will cure itself, you never know when it will fail again. Only Range Rovers since 1988 |
2nd Aug 2016 12:59pm |
