Home > Technical (L322) > Part number search bell housing rubber blanking bung.
Pepi
Hi folks can anyone shed some light on this please and provide a part number for me or better still sell me the part.
On the lower bell housing next to the crank locking pin hole is a circular inspection hole aprox 2" diameter. Normally this should be blanked off by some type of rubber bung/grommet as in "Wallis"😕
Try as I may I can't find it on microcart and worst still none of my regular suppliers can't either.
So if you can come eith one it would be a great help.
Location picture taken looking back towards gearbox. Lock pin inserted to the left of the inspection hole.
The rectangular plug for the more useful hole further down towards the gearbox is listed. Strangely enough no one seems to mention that this is a better way to line the crank locking peg up. If the plugs are out of the engine you can move the flywheel quite easily to aligns the pin from here ! Thumbs Up Eddie the eagle watch out πŸ‘€
Post #399157 4th Aug 2016 12:19pm
RRPhil
Which engine do you have?
If it’s a M62 4.4 V8, RealOEM lists a BMW part number 11 13 1 731 178, which I assume is the same part?
Phil
Post #399178 4th Aug 2016 3:41pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
LR Part number is LYB000070
BMW Part number is 11-13-1731178
You can't find it easily in Microcat because it's not where you would think it would be, it comes under the engine sump parts...ask me how I know lol!
I think I bought the BMW part as it's cheaper, 2nd hand ones on ebay for £4.40 delivered just search for BMW 1731178.
Post #399180 4th Aug 2016 3:57pm
Weejock
Beaten to it, I'm a slow typist lol!
Post #399181 4th Aug 2016 3:57pm
Pepi
Bloody marvellous
Thanks chaps you are indeed superstars. Bow down Eddie the eagle watch out πŸ‘€
Post #399217 4th Aug 2016 8:10pm
Madmax676
England 2003 Range Rover Vogue 4.4 V8 Java Black
I don't suppose you have the number for the rectangular one as well??
Thanks
Post #399250 4th Aug 2016 10:49pm
Pepi
UYB000020 For rectangular plug on the ZF box.
Check on this site for your car though
http://cat.lrparts.ru/ wait for it to load then click on your mod of car on the right. Then on transmission then on your box.
Do not press the back button! If you wish to go back, Scrole to the top of the page, then click one link back on the blue letters.
Hope this helps
Cheers
Pete
Post #399259 5th Aug 2016 6:16am
Madmax676
Access to that site is 'forbidden' using my iPad for some reason?? However found and ordered one using the part number.
Many thanks
Post #399365 6th Aug 2016 4:45am
Pepi
Site access on iPhone.
Works OK on my iPhone 5 os 9.3.4.
But it works even better on the old laptop running XP pro sp 4.
The roll overs show which illustration refers to which vehicle.
Once you get the hang of it it is quite useful for ID.' ing parts. & what should go where.
When you click on the part on screen it brings the part number up in a separate pop up.
Anyway you got your bit sorted.
Just mentioning this for others that may be reading the post.
Cheers Pete
Post #399391 6th Aug 2016 12:00pm
Pepi
Oups wrong one!!!
Post #399392 6th Aug 2016 12:01pm
