Home > Technical (L322) > Sunroof adjustment
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Sunroof adjustment
Sunroof works just fine, up/down - forward/backward no problem and everything stops when it should.
However, when it is in the closed position the rear sits about a quarter of an inch below the roof line - is this normal? If not how do you adjust it manually to stop in the right place? QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #399432 6th Aug 2016 9:18pm
There is a reset procedure in the manual.
I think that you press and hold the button in a particular direction. But off the top can't remember which way you press it. It's in the book tho Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #399434 6th Aug 2016 9:39pm
Spelunker
Yeah, gone through all the re-set procedures - it just seems to think that the quarter inch below roofline is where it should be... QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #399435 6th Aug 2016 9:56pm
mzplcg
Mine sits flush with the roof so that doesn't sound right. No idea how to adjust it though, sorry.
Post #399471 7th Aug 2016 8:57am
I seem to remember you can adjust the alignment with a small allen key but not sure beyond that . 2008 MY Supercharged
Post #399479 7th Aug 2016 9:13am
have you tried this from rave
Initialization
Initializing the roof opening panel allows the control module to learn the end positions of the motor's travel. Hall sensors in the motor provide pulses for motor spindle rotation. The control module counts the pulses and determines where the panel is by memorizing the stored pulses.
If the system is not initialized, the roof opening panel will only operate in the tilt up and slide close positions. To initialize the roof opening panel:
Using the switch, move the roof opening panel to the full tilt position and hold for 20 seconds. Release the switch.
Using the switch, close the roof opening panel.
Using the switch, slide the roof opening panel fully open, then fully closed. There is nothing that can't be fixed with a hammer😜😜
Post #399485 7th Aug 2016 10:06am
there is a procedure for the alignment of the glass as well but it is easier to inderstan with the right pics in rave.
its in the 06-09 rave manual.
Roof Opening Panel - Roof Opening Panel Alignment
General Procedures
1. NOTE: The roof opening panel must be closed Check the alignment of the roof opening panel.
The roof opening panel should be central in the roof opening.
The roof opening panel should be level with the roof, or no more than 1mm (0.040 inch) above the roof.
2. Raise the roof opening panel glass. Open the roof opening panel shield.
3. Release the upper edges of the RH and LH roof opening panel side trims.
4. Close the roof opening panel.
5. Loosen the 6 screws.
6. Align the roof opening panel glass.
Tighten the screws to 6 Nm (4 lb.ft).
7. Align the roof opening panel glass.
8. Secure the upper edges of the RH and LH roof opening panel side trims.
9. Close the roof opening panel glass. Close the roof opening panel shield. There is nothing that can't be fixed with a hammer😜😜
Post #399486 7th Aug 2016 10:10am
Spelunker
As far as I am aware the roof is properly initialized, but I will go through the procedure again. It might be that the panel is sitting too low in the frame or something along those lines - it definitely seems too low in the parked position.... QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #399549 7th Aug 2016 7:03pm
That second procedure, seems to let you lift the glass in the frame. Had a look on mine, there are a couple of plastic concertina covers on the sides, which you pull clear. This gives access to some screws which can be slackened and the glass pushed up into position if I'm reading it right.👍 There is nothing that can't be fixed with a hammer😜😜
Post #399554 7th Aug 2016 7:11pm
Spelunker
Sounds like that might be what I am looking at - I will give it a go at the weekend.... QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #399655 8th Aug 2016 8:55pm
