Home > Technical (L322) > Interior LED difficulties |
Kinch Member Since: 08 Aug 2016 Location: Idaho Posts: 45 |
Upper footwell lights is what they're called. Having the hardest time removing them. Tried again tonight. Anyone know the trick? |
10th Aug 2016 4:49am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
You can take the trim off the side and remove from there.
10th Aug 2016 6:29am |
If by trim you mean the round part that surrounds the lens, that's the part I can't get out. I've pried on it and while it will move a bit, there is not much of a lip to grab onto and the screw driver slips off. It's a matter of time before I damage something. |
10th Aug 2016 11:48am |
No, the black side panel, as you open the door, you can get a scraper or some flat tool and prise it off.
10th Aug 2016 11:58am |
Okay thank you. Will give that a try after work. Just the whole big piece of black plastic? Just pops off? I'll give it a whirl. |
10th Aug 2016 12:09pm |
Yes whole big black plastic piece. Depending on the size of your hands, it can be a little restricted in there.
10th Aug 2016 7:54pm |
Thanks! |
10th Aug 2016 8:52pm |
FYI, I got it done. Pried off the panel, and was able to reach in, grab the wire, and pull the entire bulb and fitting out, changed the bulb, and shoved it back in the orifice. Thanks for the help. |
11th Aug 2016 4:34pm |
