Home > Maintenance & Mods (L322) > Front bumper trim replacement |
Eighty Member Since: 18 Aug 2016 Location: Merseyside Posts: 2 |
I've just replaced mine and it is a to do, so hope this helps. The best way I found was to start at one end, reach behind and press the retaining clip you can feel down, while pulling the trim towards you. If you have trouble you could use a plastic pry tool or carefully with a screwdriver. Once the first one releases, work along the trim releasing each clip one at a time while pulling and it'll be off. It is just those clips holding it on. |
19th Aug 2016 12:29am |
Rrpaul2010 Member Since: 23 Jan 2016 Location: Cambs Posts: 4 |
Thanks Eighty, I'll try again after work today.
19th Aug 2016 8:00am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3685 |
I cheated and painted mine.
19th Aug 2016 8:54am |
Nice Job!
19th Aug 2016 9:05am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3654 |
I took mine off painted it but only in primer, also did the foglight surrounds, was to be a facelift project but never got round to it. Surprisingly easy actually although masking the rest of the foglight was a bit tricky - I think I used some thick rubber bands round the circumference of the fog light ring. I then sold the whole thing to another forum member and just bought the current car which had them anyway and obviously no need to do a facelift.
19th Aug 2016 9:58am |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 157 |
Anyone have any tips?
8th Oct 2022 6:38pm |
