Home > Technical (L322) > How to cure airlock? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
On the TD6 there are two more bleed screws, one needs to lift the front engine cover to see/get at them. Don't know about the petrol versions. .
2nd Sep 2016 8:47pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7909 |
The M62 4.4 is the one people usually have problems with on here but I have to say I've done mine loads of times with no issues or airlocks...
2nd Sep 2016 9:10pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 528 |
Thanks gents. Once I've sorted the drain plug I'll try it again very slowly and see if that helps. I think, but not 100%, that the basis of the N/A AJ engine is the same as the S/C? So if anyone has tips on bleeding air out of the S/C lump that might help? |
2nd Sep 2016 9:36pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
The SC can be a real pain to bleed at times! Just keep at it with a couple of loose hoses and it will eventually bleed! l |
3rd Sep 2016 10:37am |
