Home > Technical (L322) > Trans Fail Temperature |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7934 |
I imagine it's not getting hot enough for trans overheat message... sounds to me like the box has had it, pulling the tintent was the last straw...
5th Sep 2016 6:40pm |
Johnjet Member Since: 05 Sep 2016 Location: Stockport Posts: 2 |
I checked the feed/return pipes to the oil cooler from the gearbox tonight after driving home 12 miles, approx 45C lower pipe, 55C upper pipe and 80C sump. Whilst i was under the car it decided to wash/wipe the headlights all by itself!!! Jinxed? |
5th Sep 2016 6:41pm |
That's pretty cold, trans overheat come in somewhere near 120deg.... Pete
5th Sep 2016 6:42pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 913 |
As we’ve discussed many times on here, the 5L40-E transmission generally lasts between 80k and 100k miles in the L322 before the valve blocks (which GM decided to make out of cheese) wear to the extent that the spools leak and cross-talk and the resulting loss of hydraulic pressure allows the clutches – and particularly the torque converter lock-up clutch – to slip. Eventually the friction plates wear through to their backing plates, and beyond, generating huge quantities of metallic debris in the process.
5th Sep 2016 9:05pm |
