Home > Technical (L322) > 50 euros a litre for oil?! |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Ha! my rear diff oil is $170 per litre , but it might help if you tell us what FullFat you have and what oil you require .
7th Sep 2016 2:45pm |
MarkWillenbrock Member Since: 25 Aug 2016 Location: Fes Posts: 6 |
It's a 2004 bmw engined petrol 4.4 litre. Originally US market but somehow arrived in Morocco.... |
7th Sep 2016 3:43pm |
its in the wiki at the top of the page......but here you go.....
7th Sep 2016 4:16pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
ebay
7th Sep 2016 8:29pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2316 |
I buy it at around $90/L from an independent supplier. |
7th Sep 2016 9:53pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 913 |
Note that the table incorrectly identifies Dexron III as a suitable alternative to LT71141. I’ve seen, on several occasions, what happens when you put Dexron in a 5HP24. The only ZF approved fluids for the 5HP24 transmission are (part-synthetic) Mobil ATF LT71141 and (fully-synthetic) ZF Lifeguard Fluid 5 & Pentosin ATF 1. Here in the UK only the Mobil fluid is easily available at anything like an acceptable price. Elsewhere in the world the other two fluids may be easier to get hold of.
Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
7th Sep 2016 11:19pm |
I must admit I was surprised to see dextron 3 listed.... |
8th Sep 2016 1:15am |
E-diff + WA = humped 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
8th Sep 2016 1:33am |
Will Karcraft send it? |
8th Sep 2016 12:17pm |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
You might want to read this thread. One of these other brands will work fine and may be cheaper. I can get pentosin or Febi for about $10/litre delivered.
8th Sep 2016 3:17pm |
I'm carrying some febi bilstein as a reserve, but I don't think it's compatible. |
9th Sep 2016 7:12am |
It will say on the back if it is LT 71411 equivalent. I've been running the Febi equivalent. I will be changing to the Pentosin shortly because it is fully synthetic and costs the same here. |
9th Sep 2016 2:13pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Phil,
9th Sep 2016 7:38pm |
here you go Ed |
9th Sep 2016 7:39pm |
