Home > Technical (L322) > New Westminster, various small questions! |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Some of the features in the menus aren't easy to find and need the owner's manual to hand to find them at first. There might be a copy in Wiki (under the fullfatrr.com top right) if you don't have one.
18th Sep 2016 7:46pm |
Herald Member Since: 11 Aug 2016 Location: Surrey Posts: 14 |
Thanks, that's what I'm doing with the locking currently. Might be seen as better security to only unlock when a button is pushed?
18th Sep 2016 8:17pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
On mine the volume is the same as it was when the car was switched off, I had assumed that was the default setting. Perhaps it is a case of getting a LR dealer to reboot the software. Only Range Rovers since 1988 |
19th Sep 2016 11:05am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
i think if you press the tone button for a few seconds a global volume menu comes up where you can set the default volume... ... - .- -.
19th Sep 2016 11:15am |
Pushing the tone button for a few seconds gives me lots of volume settings, however none of them is for default volume! I can set the phone, nav, voice feedback and other volumes though so that's also useful thanks!
19th Sep 2016 9:53pm |
thinking about this last night and wondered if you set the required volume and then pressed the memory button on the seat....this should memorise the settings including the volume on the key fob [maybe ] ... - .- -.
20th Sep 2016 9:16am |
Zeppfish Member Since: 28 Feb 2016 Location: Surrey Posts: 57 |
Go to tone settings (bottom left button) make sure Source tone memory is enabled and set the volume before you turn the ignition off. That should sort that. As for the ignition off / door unlocking scenario, i'm not sure they do that! but if all else fails RTFM 2006 RR sport HSE
20th Sep 2016 12:49pm |
i've tried my last suggestion and it didnt work, also tried yours zeppfish and couldnt get that to work either.. ... - .- -.
20th Sep 2016 2:40pm |
I'll have a look at mine in the morning and see if I can work it out!
20th Sep 2016 8:15pm |
Tried both those too and it doesn't cure it, but thanks for the suggestions! Any more really welcome! The locking is the way it is but the volume is driving me nuts. |
20th Sep 2016 9:28pm |
tvrforever Member Since: 09 Feb 2016 Location: Bucks Posts: 53 |
Speak to Craig @ Cam-Tech - he used the IDTool to setup my Westminster settings (DLRs, auto-unlock when ignition off, dash changes etc), really makes big difference... |
1st Oct 2016 9:42pm |
Thanks, will do! |
1st Oct 2016 10:16pm |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 |
Similar sort of thing with my 2003 L322 - sometimes the volume is off, sometimes very quiet and sometimes the same as when switched off. Not had it come on too loud though so I dont worry about it but I can see where full volume on all speakers (how many are there exactly - I think I've counted 13, but not sure) could lead to serious ear-bleeding.... QUID FACIUM TIBI
2nd Oct 2016 7:01pm |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 332 |
sorry to resurrect and old post, but has anyone solved this problem: -
Like the O/P I've been to the "Volume" menu, bu as previously quoted, this just affects the offsets, not the default/startup volume. |
13th Sep 2017 3:31pm |
