Home > Maintenance & Mods (L322) > Reuse gearbox/transmission fluid |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Ford Hill, Wirral. Not Merseyside Posts: 554 |
Noooooooooooooo Tony
24th Sep 2016 3:11pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 915 |
Theoretically, operating under normal conditions & temperatures, the fluid has a life of 160,000km or ten years – at least that’s what ZF quote in the 6HP26 repair manual. Since then they’ve changed their recommendation to “a regular oil change at between 80,000 and 100,000 km or after 8 years depending upon the stress”.
24th Sep 2016 7:36pm |
If you are going to the bother of dropping the pan filter off, then you might as well put a new filter and new oil back.
24th Sep 2016 8:19pm |
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 |
I've got the fluid from the dealers already but was just wondering wether or not you could put it back in as the life is supposed to be 80-100000 miles , just wondered what harm dropping it into a spotlessly clean tub would do , I also accept a £100 on oil compared to £2000 for a gearbox is pretty much a no brainer I was mainly looking at opinions on reusing oil which has only done 20000 miles . But I'll be following the advice and topping up with new , another question how much "should" come out as several litres are held up in the cooler and torque converter? I've got 5 litres of the genuine stuff from the main dealers , all the kits I've seen come with 7 for a full fluid change .
24th Sep 2016 8:36pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3697 |
If it is clean there wouldn't be problem. Frequently with tractors and other plant and equipment where the gearbox and rear axle / hydraulic oil is all combined it usually has a life of around 1000 hours - and due to the quantity on modern large 4x4 tractors a cost of £300/£400.
24th Sep 2016 8:43pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
If it is omly 2 years old then there is no reason whatsoever why you should not reuse it,if it looks clean when it comes out why not,am not sure why some comment not to do so |
24th Sep 2016 8:48pm |
The comments are based on the fact it isn't good practice to re-use old oil of any description. Regardless of supposed life left in it unless this is being done in an operating theatre there is a high risk of introducing contaminants whereas using new oil fresh from the bottle is far less likely to do that. |
25th Sep 2016 9:54am |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
Also just think that nice new fresh oil is prolonging the life of the gearbox just a little bit more. If we all changed our engine oil for example every 3000 miles I'm sure engines would last even longer as any metallic particles however small or minimal are causing more wear. 2004 RR 4.4 V8 Autobiography |
25th Sep 2016 10:12am |
I do not understand how clean oil coming out into a clean or even new container can get contaminates into it,yes for all those perfectionists use new oil as is good practice but the question was 'could it be reused' and the answer is Yes.You could always filter it if you were in doubt. |
25th Sep 2016 10:13am |
Which was my point. You could reuse it, but only if totally clean. Unless you are positive you haven't contaminated it, with mud off the sump, dirt in the container or off your hands. Then why run the risk. if you are sure it's clean, and weren't adverse to filtering it into a clean container, and it hasn't had much use then in theory it would be fine.
25th Sep 2016 10:23am |
Yes agree there Northern but he did say it was a new gearbox so when refitted it would have been 100% new oil . |
25th Sep 2016 12:07pm |
nope, OP said in first thread that the oil and filter had been changed. There is nothing that can't be fixed with a hammer😜😜
25th Sep 2016 1:03pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2027 |
i would put it straight back in! and have a spare litre, for what might need topping up etc.
26th Sep 2016 1:29pm |
