Home > Technical (L322) > Range Rover 2003 Petrol Air Suspension Inactive |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Yes and No
7th Oct 2016 9:40am |
Vanhoolt8 Member Since: 09 Oct 2016 Location: West Yorkshire Posts: 13 |
Hi i have a 4,4 autobiography and i have the HDC fault and air susoension inactive and all the lights on and stuck in normal ride height i have put on my code reader and it says CAN bus fault and will not clear any body any ideas |
9th Oct 2016 6:15pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
^^^ Which code reader?
9th Oct 2016 6:45pm |
Firstly check battery voltage, needs to be 12 volt + no to cause silly messages on the screen of doom
9th Oct 2016 6:46pm |
Hi another forum says it could be an ABS sensor that triggers these messages |
9th Oct 2016 8:35pm |
Hi my code reader is a carsoft i930 it is for all Land Rover and jaguar models and it comes up with CANbus fault and will not clear the first time i tried it the fault cleared and then when i set off out of the driveway the messages came back on and the ABS light |
9th Oct 2016 8:41pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7948 |
The canbus fault is a standard fault that most early BMW FF's have, when Ford bought RR they wouldn't pay BMW to remove some faults that were standard to the systems, hence a fare few faults appear on all FF's
9th Oct 2016 8:56pm |
Thanks Pete my speedo is still working so which code reader do you suggest to get to the bottom of it cheers Nigel |
9th Oct 2016 9:07pm |
Personally I wouldn't have anything other than an IID tool but at over £400 they are not cheap....
9th Oct 2016 9:14pm |
Hi Pete thanks for that i have just found one on ebay for £275 this must be a good buy then for probelems on L322 then do they go into more detail |
9th Oct 2016 9:31pm |
Is it a blue tooth one? and they are type specific, ie 2002-2005 etc they can read and do more than the system the dealers use...
9th Oct 2016 10:50pm |
Buff Rio Member Since: 29 Dec 2012 Location: Banstead Posts: 36 |
Update.
11th Oct 2016 11:34am |
Glad your sorted... I do that as routine... clear the faults and see if they return, otherwise you just waste money on bit's you don't need.... Pete
11th Oct 2016 3:02pm |
Hi I have put my code reader on agin today and I am getting precharge pump fault so I have put another one on still got same faults and will not clear I also have precharge pump pressure sensor fault and don't know where to find that but I also checked wires to pump and no live any body any ideas |
11th Oct 2016 7:47pm |
