Home > Technical (L322) > Air Conditioner Compressor Questions
georgedb
South Africa 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hi all
When making reference to the AC Compressor is it the same as referring to the AC Pump; i.e. are they seperate parts or the same thing?
Are AC Compressors interchangeable between the various moeels and MYs?
Had compressor tested and sitting at 10V where it should sit at about 2V once engaged with vehicle on but not running (according to techie).
Cheers
Post #409303 14th Oct 2016 3:35pm
miggit
The A/C compressor and the A/C pump are the same thing, which is driven off the engine.... the 10v that you refer to could be the magnetic clutch that engages the pump when it's required... however is that what your tech is talking about or is he referring to the EAS pump which is electrical?
If the A/C pump is only getting 10 volts then I would suspect that you have a burnt relay Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #409304 14th Oct 2016 3:43pm
georgedb
Thanks Miggit for the feedback.
He is referring to the compressor that remains at 10 bar and not moving down to 2. He said the aircon is still full but the compressor needs to be refurbed for which he needs two days and to remove the belts.
Where would I find the relay you are referring to (please)?
Post #409322 14th Oct 2016 6:33pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Looks like the tech has checked the Low side port pressure of the AC.
Without the compressor running the pressure throughout the AC system equalizes and will be around 10 bar on any port (depending on temperature, volume in the system etc.).
With the compressor running the compressor suction side pressure (Low side) should indeed drop as it compresses the gas raising it on the discharge side (High side). Around 2 bar on the Low side is about right with the system running.
If it's not doing anything when AC is requested then it's likely an electrical problem where the compressor is not engaging.
Why it's not engaging could be for a number of different reasons. It could be a faulty sensor, wiring issue, faulty HVAC ECU module or failed compressor clutch engagement coil amongst other problems.
I would hope these were all checked before the Tech condemned the compressor itself.
A diagnostic tool can be used to command the compressor on ignoring all other sensors and inputs. If it doesn't work when commanded by the tool then the clutch coil circuit needs checking. If it does work then the HVAC system sensors and wiring needs checking.
Without a diagnostic tool then the coil resistance can be checked (should be no more than a few Ohm) and 12V supplied to it to see if it can operate the clutch on the front of the pulley.
Unfortunately you are reliant on the garage to be able to investigate electrical faults to definitely confirm where the problem lies. That takes knowledge and time which it seems nowadays very few garages are able and willing to do. They tend to go down the route of replacing parts until they get lucky. Given hourly rates that are charged for diagnostics of a fault then the part changing route might actually work out cheaper to the customer but it's a gamble that might mean perfectly good parts are replaced for no reason.
Of course they might well have done those checks and the compressor is broken, the 10 bar and 2 bar answer you got though is not a definitive answer to condemn the compressor.
Post #409356 15th Oct 2016 1:13am
georgedb
Thanks weejock
Seems he only checked the low side and no other tests were done
Post #409360 15th Oct 2016 7:09am
