Home > Technical (L322) > Td6 temperature gauge |
Imbigt Member Since: 24 Sep 2016 Location: Romford Posts: 76 |
At what position should the needle sit at when hot |
3rd Nov 2016 9:56am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7962 |
12, o'clock when up to correct temp... Pete
3rd Nov 2016 10:53am |
Zulu 10 Member Since: 28 Nov 2014 Location: Hampshire Posts: 88 |
Beware that the needle position is not a direct feed from the coolant sensor: instead it is the ECU's interpretation of the value produced by the sensor.
3rd Nov 2016 10:02pm |
All modern vehicles now have gauges that do what the maker thinks you need to know... Not sure on the TD6 but the M62 get's to normal at under 80 degrees and then doesn't move off normal until the temp gets above 115-120 deg a bit useless for measurement like an old gauge, they may as well just have a light... Pete
3rd Nov 2016 11:30pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 777 |
Once warm mine sits squarely at 12 oclock but its not always been that way. When I first got the car the gauge was always on the low side, dropping lower when I was on a long run. After researching here and investigation I found the EGR thermostat was knackered, stuck open. Fitted a new one and now all good. Simple fix if thats your issue. This vid will give you an idea, not exactly the same, ours have a different hose fitting.
4th Nov 2016 1:48am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I can say with confidence that normal starts at 60 and goes over 100 degrees as I have a proper temp gauge on my ffrr too... so if your gauge isn't getting to the 12 o'clock position I would suspect that you thermostat is in the open all the time, or fubar mode
4th Nov 2016 9:46am |
4th Nov 2016 5:14pm |
If that is where it sits after a run then I would say that it is a bit low on the temp.... However it could be the gauge... the needle might be in the wrong place..... I would suggest that plugging in a IID tool might be a very good idea, as you can see the temp that the ECU is seeing...not what it thinks you want to see.
4th Nov 2016 7:29pm |
I will plug it into my launch what should it read in relation to the gauge |
4th Nov 2016 7:54pm |
Well normal should be around 75 - 100 degrees centigrade, as long as your over 70 then I wouldn't worry, if it's below then I'd be looking at the EGR thermostat and then the engine thermostat... but the EGR one is way easier to get at Yesterday I couldn't spell Engineer... Today I are one!
4th Nov 2016 7:58pm |
Yes but eBay don't have them listed |
4th Nov 2016 8:24pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
Search for item 11712247723 on eBay. |
4th Nov 2016 8:48pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
17 mpg
4th Nov 2016 9:10pm |
I don't hang about |
4th Nov 2016 10:26pm |
