Home > In Car Electronics (L322) > Cigarette sockets staying active when locked?
phillips321
United Kingdom 2003 Range Rover HSE Td6 Galway Green
Hi guys,
When we look the car the cigarette 12v sockets stay live. This will lead to a flat battery in time as when travelling we will leave in various things like the fridge, phone chargers, laptop charger etc...
Is there any way we can set the 12v sockets to turn off when the car is locked?
This is a 2003 HSE.
Many thanks
Post #412401 6th Nov 2016 7:29pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I'm not sure but don't the sockets power down after 16 minutes, just like the lights if you leave a door open.
Like I said I'm not sure, so hopefully someone with experience of this will be along shortly....
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #412402 6th Nov 2016 7:35pm
phillips321
This is appreciated, i'm trying this out now, will go back outside at 1900 and confirm either way Smile
Thanks
Post #412404 6th Nov 2016 7:46pm
UK Marine
Whatever you do don't open the doors as that might wake up the sockets. ______________________________
Simon
Post #412407 6th Nov 2016 7:58pm
phillips321
Car's been outside for the past 20 minutes so will go and check now. I haven't touched it or opened any doors.
Thanks
Post #412408 6th Nov 2016 7:59pm
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Im sure I saw a post going through how to change the sockets to ignition switch controlled..... QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #412409 6th Nov 2016 8:00pm
phillips321
Just checked and the one near the key is still on Sad Not sure how long to leave it.
How can i confirm the car is 'going to sleep' as when we went to collect the car it had been sat for a while and had a flat battery.
Thanks
Post #412412 6th Nov 2016 8:07pm
UK Marine
Try the gear selector position lights, they should go out after the allotted time of 16 minutes. Be careful though as I've found that trying the tailgate release switch on the tailgate wakes up the gear selector position lights. Not sure if that wakes everything else though........... ______________________________
Simon
Post #412413 6th Nov 2016 8:14pm
The sockets are either on all the time or ignition controlled on a 2003 car, no delay after the ignition is switched off.
It's possible they are on all the time due to bridging pieces being fitted in the relay bases mounted below the rear fuse board. If this is indeed the case it should be a simple matter to remove the bridging piece(s) and replace them with relays to make them ignition controlled.
Is it possible you could take a photo of the rear fuse board and relays and I'll have look for you.
Which sockets do you want ignition controlled, there are two aux sockets and two cigar sockets.
Post #412414 6th Nov 2016 8:15pm
phillips321
Hi thanks for the help. Here's the rear fuse box:
Post #412419 6th Nov 2016 8:36pm
UK Marine
I've looked at the wiring diagram and it appears that both the cigar lighters and the accessory sockets are live all of the time. They just go from the battery to the fuse boxes then to the sockets...
Simon
Post #412423 6th Nov 2016 8:48pm
@ uk marine, I agree that's what the wiring diagrams show but cars do seem to vary for some reason ie cigar sockets can be ignition controlled or not, same with aux sockets. My cigar sockets are permanently live but my aux sockets are ignition controlled.
@ Phillips 321
I'm having to do this from memory as I don't have my PC with me but I think you will find the yellow "relay" is in fact a bridging piece. You can check this by pulling it out, it will have two pins not four as with a normal relay.
If you pull it out which sockets go off?
If this is indeed a bridging piece you can just replace it with a good quality 30A 4 pin relay, buy one without an inbuilt diode, for some reason the diode causes a problem.
Post #412434 6th Nov 2016 9:10pm
phillips321
just tested, pulled the yellow one out and the 12v socket went off Smile
I'll swap this out tomorrow with a good relay. How would i test for a diode relay?
Post #412438 6th Nov 2016 9:21pm
The easiest way is to ask for one without a diode. Very Happy
Mine are somewhere in the garage so not accessible at the moment to check. Thumbs Up Which socket went off?
Where you pulled the bridge out does have facility for four pins?
Post #412442 6th Nov 2016 9:31pm
phillips321
I only checked the single one that was plugged in (next to gear lever).
I didn't check but was it a 4pin or 5 pin?
http://www.halfords.com/webapp/wcs/stores/...;langId=-1
Post #412443 6th Nov 2016 9:34pm
