Home > General > Just typical.......!!!!!
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
When I get some time off I shall try and find a bodyshop to sort it. I've only used a body shop once, recommended by a ,ate. They didn't do a great job on wifey's car many moons back. So, time to shop around.
Post #414370 19th Nov 2016 2:07pm
Worth shopping around, don't go with the cheapest, go with the one with the nicest cars on the lot! There are a few I have used round here and the guys I used for the bumper weren't the cheapest but they were the only ones who said that they would take the bumper off! There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #414394 19th Nov 2016 6:45pm
Rob99
Bit of an update on my rear parking sensors.
Have been putting up with their intermittent behaviour for months but as the fattie was at the dealers for an MOT today got them to investigate again, figuring they will be covered by warranty if there's a problem found.
Got a call mid afternoon....."yes we have checked the system out, no faults showing but it's still not beeping correctly. we were about to start unplugging individual sensors and then discovered that the reason they probably aren't working is because they have been painted over".... Shocked Shocked
Upshot is that new sensors aren't covered by warranty as they haven't failed (just been painted). It seems that the previous owner must have scuffed the bumper at some point and probably just took it to a cheap bodyshop for a quick blow over, probably just before he traded up to an L405 Whistle
It's bugging me now so I will have to get new sensors and fit them myself, dealer wanted ฃ600 to do it Shocked
At least I know what the issue is.
. 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #437192 5th May 2017 6:53pm
StewD
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
F**k that.....
pop the sensors out and try to remove the paint first.... Current: Supercharged 06 FFRR in Java Black
Previous: BMW 740D M Sport
Previous Previous: BMW 730D Sport
Post #437197 5th May 2017 7:21pm
strange...parking senders are painted to match the colour of the bumper/car... ... - .- -.
click link for ,
FORUM WIKI
HOW TO ฦŽ๊“•โˆ€๊“•O๊“ค PICS
Post #437200 5th May 2017 7:40pm
StewD
Stan... my point exactly... they don't get the full thickness a body panel would get...
I'd be extremely surprised if you can't get them cleaned up. Current: Supercharged 06 FFRR in Java Black
Post #437204 5th May 2017 8:28pm
Rob99
Mine do look like they have been painted in with the bumper re-spray so.......
1. How easy are the sensors to remove? Do I need to take the bumper off?
2. Whats the best way to clean the paint off? Would sitting them end on in a couple of mil of cellulose/brake cleaner for a couple of hours work?
Post #437223 6th May 2017 7:41am
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Whatever means you use, I would only do one to start with. How about something as simple as fine wet and dry or 1000 wire wool, at least that won't damage the plastic.
Post #437241 6th May 2017 1:09pm
Baltic Blue
Try dipping the end of a cotton wool bud in cellulose thinners then rubbing one before going to the trouble of removing them. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #437243 6th May 2017 1:19pm
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
I found that corrosion was causing the paint to 'bubble' on a couple of mine causing the sensors to activate when there wasn't anything near them. A good clean up and repaint cured the problem... QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #437286 6th May 2017 7:45pm
