Home > Technical (L322) > Stainless exhaust for L322 TDV8? |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Keep us posted on your findings |
17th Nov 2016 9:27pm |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 |
just find an independant exhaust maker they are usually found in performance car garages although some tyre places will have someone who can custom make one for you L322 2008 vogue
18th Nov 2016 9:50am |
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 |
Im going to have the cats and whatever the first small muffler is not far after them (My car does not have DPF's) removed from my 2010 TDV8, I am chasing better flow and some more exhaust note as you are
18th Nov 2016 3:49pm |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 |
Ordinarily I would just remove my cats altogether, but the new MOT rules over here prevent that now
19th Nov 2016 10:04pm |
depending on how handy you are with spanners you could always get the cats cut out and flanges welded and also have two straight through pipes made so come MOT time you swap them over or just replace them with a 200 cell cats L322 2008 vogue
20th Nov 2016 12:14am |
Well, it's arrived and it's good news. Yes, it does look exactly like the pictures on the Direnza site. and yes it does have a cat inside it when I checked with a torch.
21st Nov 2016 3:11pm |
Ok, having finally had them fitted before the MOT on Wednesday, it appears that there are a few slight issues.
25th Dec 2016 12:40am |
We had no luck fitting my friends either..if you find a solution to sealing the joints up properly please share ..one thing to note with the system it sounds amazing... |
25th Dec 2016 2:50pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
These might do the job... Commercial flexi exhaust clamps... they are designed to seal up on 2 different size pipes, I'm fairly sure that TTC (Truck and Trailer Commercial) do them, and most truck spares places deal with them
26th Dec 2016 1:16am |
Good shout buddy..i will hunt some down..if it works im going to purchase a direnza setup myself... |
26th Dec 2016 2:30pm |
