Home > Technical (L322) > Refilling problems on my L322 FFRR TDV8 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7651 |
You need to reset the misfuel device.... you should see something yellow blocking the filler. You should have a yellow plastic tool to do this. It's in the manual....
27th Nov 2016 10:50am |
Jambo Member Since: 15 Oct 2016 Location: Cumbria Posts: 20 |
Exactly the same happened to me the first time I filled it up. Took a while to work out what it was, but resetting fixed the problem.
27th Nov 2016 12:41pm |
Smee55 Member Since: 27 Nov 2016 Location: Fife Posts: 4 |
Hi guys
27th Nov 2016 2:01pm |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 |
I removed mine all together saved this hassle. Range Rover quotes.....
27th Nov 2016 2:07pm |
How did you remove the fuel stop. |
27th Nov 2016 2:10pm |
I'd remove mine if I knew how.... I can't even put the correct nozzle in far without it triggering.......
27th Nov 2016 2:34pm |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
I always put the hose in with it turned through 180, looks a bit odd but can get full flow.
28th Nov 2016 10:05am |
peekay Member Since: 07 Nov 2011 Location: London Posts: 90 |
/\ /\ Exactly this - a bit of a strange approach but it works. I heard about this trick from a mechanic in a pub - thought it was nonsense until I tried it and it worked. Don't seem to have same problem on L405 |
28th Nov 2016 11:56am |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 500 |
same here - turning the nozzle upside works fine for me. MY11 Vogue 4.4 TDV8 - "African Queen" |
28th Nov 2016 12:18pm |
Trebaix Member Since: 17 Feb 2015 Location: Leics Posts: 24 |
Yep - turn the nozzle upside down 180 degrees.
29th Nov 2016 6:43am |
