Home > Technical (L322) > remote FBH fob operation?
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Can anyone clarify the operating parameters of the FBH remote on my 2011 tdv8
Have only had the car a few months (i.e warm weather) and have recently programmed the fbh key fob. When the on button is pressed the light flashes green on the fob and an orange light flashes on the centre knob of the climate control
from inside the car it appears to open the centre dash air vents and allow a very weak airflow into the car
The coldest i have seen since getting the car was about 11degres (ext temp) but at this temp the fbh doesn't appear to fire it only "vents" the interior
So my question is-
1- is this correct operation? or can i increase the blow from the vents when on somehow (mainly to keep the dog cool)
2- at what temperature does the car decide that it needs to heat rather than cool the car and fire the FBH into life?
thanks in advance
Paul Thumbs Up Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #403556 5th Sep 2016 10:55pm
andygts
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
If I remember right it will try to maintain 16°C internal ambient temp so will activate the burner if required.
It will only blow on fan speed 1 and through the centre vents unless the external temp is around freezing point then it switches to blowing on the screen. Current
2001 Porsche 911 Turbo
_____________________________________
Previous
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #403564 5th Sep 2016 11:47pm
marsie
Cheers Andy, so i am guessing it will need to be considerably colder than 16 before the fbh fires ? Thumbs Up Paul
Post #403589 6th Sep 2016 9:30am
mzplcg
The FBH itself fires at 5 degrees I recall. Above that it will vent the car rather than heat it.
Post #403599 6th Sep 2016 9:56am
marsie
thanks guys, guess i will need to wait a couple of months to see if it works then Thumbs Up Paul
Post #403793 7th Sep 2016 6:39am
bishbosh10
Any progress on this?
My FBH works when programmed from the dash and generally on cold mornings but the remote fob only flashes a red LED when I press the on button which according to the book of lies means it didn't connect with the car, despite me standing right in front of it!
Shouldn't be a fob battery issue as then the LED should flash orange I believe?
Is there a setting in the car that I need to adjust so it recognises the remote or am I off for a warranty claim?
Thanks! Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #416028 30th Nov 2016 5:15pm
andygts
Have you tried re syncing the remote?
Disconnect power from receiver, reconnect and press off on the remote within a few seconds. Current
Previous
Post #416029 30th Nov 2016 5:35pm
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
How does one disconnect power from the receiver please? Think I might have the same issue..
Post #416125 1st Dec 2016 8:38am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Temperatures...
In the 2011MY, FBH fires at 15 degrees or below. Not 5 as posted above.
Post #416127 1st Dec 2016 8:42am
TomCobbly
The receiver is located behind the rear offside (RHS) access panel in the boot. It has two plug-in connections and you need to remove the one with three wires coming from it. The plug just pulls out but it can be quite a tight fit. Leave it out for about 30 seconds then plug it back in and press the off button on your remote within five seconds of replacing the plug. I'm not sure if this is the official method but it worked first time for me Very Happy 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #416133 1st Dec 2016 10:32am
Zeb
Thanks for that!☺
Post #416137 1st Dec 2016 10:44am
Stuart
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
TomCobbly is right.
Did this with mine yesterday, and it paired straight away.
The Webasto unit is a small, thin rectangular metal unit measuring about 4" x 3". It has 2 connectors plugged into it, and is situated at the rearmost of the boot (driver's side, above the fuse box). It should have the Webasto logo on it (a W made to look like a steering wheel - if unsure, google it).
Post #416138 1st Dec 2016 10:45am
bishbosh10
Well mine now works Very Happy
Seems a new battery fixes a multitude of sins! Rolling with laughter Embarassed Embarassed Embarassed Bish.
2005 110 TD5 CSW
Post #420714 2nd Jan 2017 11:50am
