Home > Technical (L322) > TDV8 4.4 Vogue - aux heater? |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 452 |
If you have park heating (no fob) is it possible/practicable to retrofit remote functionality? 2016 (L405) Autobiography in Black with Ivory - for ULEZ
16th Mar 2014 8:17am |
Berty Member Since: 05 Jan 2016 Location: Leeds Posts: 73 |
I have a 2012 autobiography with the park heating remote yesterday morning -3 I used it and it seems to be blowing just cold air around, it didn't defrost the screen only the mirrors, no heat in the cabin and I used it on two cycles,although I could hear fans going and could smell fumes,but no smoke when I started the car the temp gauge was still clap cold to, which I understand it should warm the coolant a few degrees and move the gauge, anyone any ideas or similar problems? Thanks Berty |
30th Nov 2016 9:11am |
That sounds broken Berty.
30th Nov 2016 9:00pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
The engine temperature gauge won't show anything because the engine is isolated out of the coolant loop when the FBH is running alone . If it wasn't all that would happen during the FBY cycle is the the engine block would take all the heat for a net gain of a couple of degrees . 2008 MY Supercharged
1st Dec 2016 2:43am |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 120 |
Does anyone know if there is a service interval for the FBH? I'm thinkig of things like changing the air filter or cleaning the glow plug/flame sensor and injector? I can imagine things getting pretty clogged up if the air flow gets restricted 2011 4.4 TDV8 Vogue SE
1st Dec 2016 3:46pm |
no service interval for them. they are pretty clean burning if running correctly. They are easily accessed though, just the inner arch liner which needs to come off. then the hoses can be clamped and the unit removed. There is nothing that can't be fixed with a hammer😜😜
1st Dec 2016 6:15pm |
stefan063 Member Since: 28 Aug 2016 Location: Kragujevac Posts: 39 |
I have EXIDE GEL battery. 100Ah. Working great. A bit expensive then normal batteries. FBH work like a charm with remote |
1st Dec 2016 8:12pm |
In what shape is you battery? Mostly everything depends on VOLTAGE,second air temperature and etc.... Check user manual. Everything says there... |
1st Dec 2016 8:15pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 763 |
About to install a varta AGM 105ah battery......
1st Dec 2016 11:38pm |
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 167 |
I’ve just pick up this thread....being a new owner Aug 18.....I’m looking to see if my 2011 VSE aux heater works. So far I get nothing out of it. I can only change the set time but I don’t have a remote fob. Do I need a remote fob?
1st Feb 2019 3:57pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7640 |
Manual via fob is an option I think. It’s fitted to help the car warm up on cold days. It’s not a disappointing feature. You being able to set it to come on is just part of what it does....
1st Feb 2019 5:08pm |
Does anyone have any pictures or diagrams to show where the heater is located on a 2011 Vogue SE?
2nd Feb 2019 8:09pm |
It’s under the passenger side wheel arch, sort of under the battery location. There should be a little exhaust sticking down there too. 2011 Range Rover Vogue SE 4.4 TDV8
2nd Feb 2019 8:19pm |
Thanks for the location....I’ll have to have a look.....no idea why it doesn’t work. Do I need the remote as well? |
2nd Feb 2019 8:22pm |
