Home > Technical (L322) > 020 Battery fitting |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 762 |
I have bought an 020 to go in..I will let you know how I get on. |
2nd Dec 2016 7:04pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1694 |
I have also bought an 020, and fitted it. Unfortunately, the battery terminal wouldn't fit. Seems the 020 is too long...
2nd Dec 2016 10:14pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 285 |
Hallo together, at 2011 4.4TDV8 313hp fixed this one: http://www.ebay.de/itm/371034812384?_trksi...BIDX%3AIT, only problem is the ECU box, one screw, 30 minutes, and in time of changing I give 12V to the car with externe battery..., best rgs, Uli TDV8 4.4 from 2012, 278.000km like new + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
2nd Dec 2016 10:40pm |
That's not the correct AGM battery |
3rd Dec 2016 10:03am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
Thanks gents - one says yes (even if it isn't an AGM) one says no so I'm still just as confused
3rd Dec 2016 5:55pm |
Ok. I have set aside the 12th to have a go. (I am working in Amsterdam next week).
3rd Dec 2016 6:27pm |
Th battery dimensions seem very critical. 350mm long is around the max, and an 019 fits the bill perfectly
3rd Dec 2016 9:21pm |
393 mm is the length of the 020.
4th Dec 2016 10:53am |
had a look at the bits bolted to the battery today.
4th Dec 2016 6:50pm |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
Sorry to keep reviving threads......
12th Jul 2017 12:07am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
What's the difference between a 019 and an 020?
12th Jul 2017 12:37am |
The 020 is physically longer and is rated at 110AH, the 019 is rated at 95AH.
12th Jul 2017 3:58am |
I tried the 020 in another FFRR, and it still didn't fit
12th Jul 2017 7:01am |
020 is 40mm longer. Looks like ill go for the 019 then. The old one im taking out may be good enough to use in a dual battery setup if it will fit in the boot. 2011 RR Autobiography 4.4 TDV8 |
12th Jul 2017 10:11am |
