Home > Technical (L322) > Can chain guides shatter due to cold? |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
Hi,
4th Dec 2016 6:48pm |
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 |
What a coincidence the very same happened to mine on Friday. |
4th Dec 2016 7:09pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3077 |
Thx boatie, yeah know about how to find the bits but Any ideas if it may be something else at the top of the block before I go the whole hog? |
4th Dec 2016 7:39pm |
Hi mick gulp! Have you had anyone look at it yet ? Any ideas on repair Costs? |
4th Dec 2016 7:40pm |
Boatie - haven't heard that in a while ______________________________
4th Dec 2016 7:53pm |
I think the diesel sound gives it away. I have heard of people driving theirs in that condition but I'm not so sure that I would.
4th Dec 2016 8:08pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2030 |
+1 on dropping lower sump. You can put the oil back in it's not!
4th Dec 2016 8:27pm |
Hi,
4th Dec 2016 10:18pm |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 |
This happened recently to mine. Clatter like diesel noise. Thought initially it was the vanos as was coming from the front of the right hand bank as you face the engine. Then about a week later I got a high pitched whine and the engine was sluggish as if there was increased friction. Held a short copper pipe against the block and to my ear to pinpoint the noise and dropped the pan after some research, my noise is top right. 3 Guides are front centre and top left and right of the Vee. Anyway, F&€@ing plastic bits everywhere. 129k miles and poxy valve guides have delaminated and part of one is trapped between block and chain and that's where the whine is coming from. Whoever thought aluminium guides covered in plastic was a good idea should be shot. Not worth doing the work so bye bye rangie. Don't drive it as the swarf could end up everywhere in your engine including oil pickup point and block the pump. Lot of info on this on the american beemer forums. seems to be a common failure at the 120k mile mark. Lots of discussion about how different types of oil can encourage the part to fail |
5th Dec 2016 12:27am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I have just done the job myself if you search my recent posts. I have also had a really nasty noise in the past that was the water pump bearing.
5th Dec 2016 1:04am |
Info regarding my timing chain rebuild here
5th Dec 2016 1:07am |
Good point on the 105 temp in the cooling system, no wonder the plastic and rubber bits perish so easily. I don't know if BMW run the x40 engines at the same temp but certainly in the US where they have a lot more examples of this engine it seems to be guides go at 120k or not at all. It's a good idea to factor into pre emptive maintenance plans and wish I'd known about it sooner |
5th Dec 2016 12:09pm |
That's why one of the best mods you can do to your Range Rover is the thermostat mod. I did mine and it sounded and felt so different, more relaxed if that sounds right.
5th Dec 2016 2:19pm |
I have the kit to do mine but didn't get around to it which is why mine blew its top hose off on Sunday on a dual carriageway and dumped all its coolant out and went home on a lorry ..,., |
6th Dec 2016 1:17am |
