Home > Technical (L322) > Intermittent lumpy idle and smoking, and also fbh issues |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 |
Just to add - I have done lots and lots of searching before deciding to write this post! 2007 Vogue TDV8 with 255/55/20's fitted |
5th Dec 2016 11:29pm |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 338 |
Have you monitored the EGR's live data both commanded and actual and see if they both pretty much track the commanded value. Would have thought a fault code would appear if they were bad.
6th Dec 2016 12:27am |
Morning Andy
6th Dec 2016 9:49am |
Running out of suggestions, keyboard mechanics isnt very easy with these types of problems.
6th Dec 2016 6:33pm |
Yes its odd hence posting out of desperation.
6th Dec 2016 6:44pm |
The egr's are still sometching that I'd want to check even though they are appearing to be fine.
6th Dec 2016 7:21pm |
Yes I agree about the EGR's.
7th Dec 2016 9:30pm |
Think mine were about 250ish each Current
7th Dec 2016 11:21pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Unlikely to be this, but worth thinking about.....
8th Dec 2016 4:06pm |
This is all good so far.I decided to, as preventative maintenance, order a pair of EGR's, as whilst it may not solve this particular fault I can definitively rule them out and know that they've been done - which has worried me for a few months.
9th Dec 2016 10:20pm |
I'm fairly confident its an EGR fault. Current
9th Dec 2016 11:11pm |
Ordered them on fleabay, looks like one listing wrong so now have two of one side coming unless seller catches up with messages before sending.
10th Dec 2016 5:58pm |
So, thermo housing has stopped the job.
20th Dec 2016 6:52pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
20th Dec 2016 7:42pm |
