Home > Technical (L322) > Deployable Side Steps Fitting |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 |
May or may not have bought some deployable side steps from ducky Dan today
13th Dec 2016 11:10pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34930 |
theres info in the wiki ... - .- -.
13th Dec 2016 11:14pm |
Thanks Stan just seen them. I definitely checked the Wiki before i posted, even searched the forum. Perhaps i was spelling it wrong. It's been a log day Jordan
13th Dec 2016 11:21pm |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 338 |
the wiki stuff is for 2010>
13th Dec 2016 11:26pm |
no problem jordon mark has done a great diy write up and as he recommends , get a tap set for the rusted/dirty screw holes.. ... - .- -.
You made it look easy Mark!!!! Hope i don't struggle too much.
13th Dec 2016 11:31pm |
There are pre installed threaded holes on the cills and main rails that steps bolt to. These were rusted to the point that they wouldn't take a bolt, a quick run through with a tap and the bolts went straight in. Dead easy to tap out the rust. on the main bolt holes and passenger side cill holes, the drivers side is a bit diffeeent as the air tank is blocking access slightly. There were some bolts in the rear holes on this side already so I used these on the front set of holes as they were easier to get in the rusted holes at the front. There is nothing that can't be fixed with a hammerππ
14th Dec 2016 12:39am |
Got a delivery from Santa aka Dan From Duckworths yesterday!
20th Dec 2016 3:11pm |
nice toolbox..
20th Dec 2016 3:22pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3654 |
Every time I see one of these posts about steps it serves to remind me I made the right decision (for me anyway) - get someone else to fit them Geoff |
20th Dec 2016 3:51pm |
Ok. So I've got so far and now got stuck. It's been relatively easy and I've taken a few pics to document the process.
24th Dec 2016 3:32pm |
Completed the job. The problem i was having was with the instructions. When connecting the steps for the first time to put them in access mode. You need to keep the DSS button held WHILE you turn the ignition, which i wasnt doing. This will liven them up and they worked fine after that. Kind of like a initiation step!
3rd Jan 2017 3:53pm |
good job sir |
3rd Jan 2017 4:09pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
Nice job
3rd Jan 2017 5:17pm |
