Home > Technical (L322) > central locking |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Did another battery reset...the internal button now opens all locks...key will only open drivers door only? Its like when the battery's dead and you can only get access to drivers side....? Cars starting ok ..if my batteries dying could it cause the door lock issue?.. |
14th Oct 2016 1:16pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
a new battery is a good place to start.. ... - .- -.
14th Oct 2016 1:17pm |
Was thinking that..maybe that's affecting bcu and in turn affecting ability to sync key and unlock all other doors externally? Any recommendations foe a good battery? Have a bosche one in it just now...cars only getting started in garage as its off road during its work getting done to it..batterys probarly dead...thanks |
14th Oct 2016 1:21pm |
Tested battery and its needing renewal..will try and charge it first the test it....somehow solved the unsynchable keyfob...simply pulled the rf receiver fuse then it worked! ??
14th Oct 2016 1:58pm |
Madmutt0 Member Since: 18 Feb 2016 Location: Bristol Posts: 78 |
Hi I'm having the same problem with my kkeyfob could you tell me what fus number you tried and did a new battery solve your problem thanks bob |
14th Dec 2016 5:21am |
It ended up an easy fix..i had pressed the keyfob buttons too many thanks times which did something to the rf receiver...all I did to fix it for was briefly pull the fuse for the RF receiver then I was able to re synchronize the key fob with the car...easy! |
14th Dec 2016 6:15am |
Pull fuse 14 in the rear fuse box (right hand side.in boot) I then put key in ignition and turned to position 2 ..take key back out then refit fuse( check its ok first) then try and resynch keyfob
14th Dec 2016 3:34pm |
I think it is also the case that certain keypresses or combinations on the remote will enable/disable the 2 stage unlocking function. It was certainly like that on my 07. First press would unlock driver's door only, 2nd press would unlock the rest of the car. If you disable 2 stage locking then one press unlocks the whole car. |
14th Dec 2016 3:37pm |
