Home > Maintenance & Mods (L322) > 2003 - Air susp Inactive, clean sensors? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Have you tried the full lock to opposite full lock and back... this should reset the EAS and clear the screen of doom Then if that works, I think I'd be putting it into high switching off and go around the car listening for a hiss... hopefully it will be the source of the problem and not a snake
28th Oct 2016 10:35am |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 719 |
Sorry for the late reply Miggit, had loads on at home and only had a chance to sit back down. Yep, tried the lock to lock but nothing, fault still there.
15th Dec 2016 12:05pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3194 |
Might be worth trying http://bagpipingandy.com/compressor.html
15th Dec 2016 12:40pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Along with the piston ring kit mentioned above I would change the air drier granules.
15th Dec 2016 1:14pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Best thing to do before spending money is ask the guy who cleared the faults, what the fault was, if you know which part of the system is at fault then it saves just chucking money at it, it could be a height sensor, a valve block and quite a few other things as well as the compressor...
15th Dec 2016 1:28pm |
You may get away with putting the granules in the oven, I certainly hoped I could.
15th Dec 2016 2:23pm |
Fair point, I'm a northerner now so like the "cheap" route... mine were pretty white and looked fine, maybe they had been replaced in the past... Pete
15th Dec 2016 2:58pm |
Thanks all, am going to have a go at refurbing it myself with the kit, errrrr where do the drying granules go please? (never pulled one apart so no idea I'm afraid)
18th Dec 2016 3:35pm |
Very obvious when you get it apart, be careful, if they are dry they are nearly lighter than air and go everywhere with the slightest breeze..... Pete
18th Dec 2016 3:50pm |
WABCO drier granules replacement video
18th Dec 2016 11:57pm |
Thanks everyone, so would you go down the repair it route first? Watched a video and it said buying a new compressor everything in it is new, where as repairing it only the piston ring and seals are new.
21st Dec 2016 9:43pm |
There's something reassuringly reassuring about a northerner working on t'car |
21st Dec 2016 9:49pm |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 |
Had the same on my old one, new compressor, still not cured.
23rd Dec 2016 2:29pm |
Interesting Stormin, is the tank something you can see just by laying under the car? (thought I'd check if its an easy thing to eliminate)
14th Jan 2017 2:56pm |
