Home > Maintenance & Mods (L322) > door cable |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Its a basturd , I did it by absolute blind luck, not much help sorry, but I feel your pain. At least you didn't fit a new cable wrongly which pinged off when the door shut and you then had to bend the door card to get the fecker off.. |
15th Dec 2016 4:19pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Offer up the door card and make sure the inside handle is pushed in, then insert the black plastic end in and it should clip in,
15th Dec 2016 6:01pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
15th Dec 2016 6:55pm |
vmaxer Member Since: 22 Jun 2016 Location: staffs Posts: 110 |
thank you thank you thank you sorted |
16th Dec 2016 2:31pm |
16th Dec 2016 3:13pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
One of my pals has this problem with his ffrr.. turns out that it's the cable window regulator slipping, and the only fix is a new regulator... and according to my pal it's a rather involved job Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
18th Dec 2016 4:05pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3059 |
Changing regulator is not as bad as u think miggit. I did it myself and it took a coupla hours but then I am a complete numpty when it comes to things like this. But all good and all working fine. |
18th Dec 2016 8:07pm |
I just don't understand why the glass has to come out Rave isn't very clear on why, from what I can make out the regulator doesn't come out through the glass opening... so why do they remove it? Yesterday I couldn't spell Engineer... Today I are one!
18th Dec 2016 10:44pm |
Because of the shape of the rear door (with the rear wheel arch curve) the glass cannot be lowered enough to fully clear the 2 retaining bolts - It covers one of the retaining points of the regulator if left in. You have to remove the glass to be able to get your Allen key/Torx thingy in. |
19th Dec 2016 10:30am |
Which bloody sadist designed that one then... it does make me wonder if they deliberately go out of their way to complicate things
19th Dec 2016 9:47pm |
