Home > In Car Electronics (L322) > Help needed all comms
Madmutt0
Hi been told that my keyfob problem is due to transport mode is ther anyone ne'er Bristol who has all comes
That can remove the code willing to travel and pay for help thanks
Post #417829 14th Dec 2016 4:59am
holidaychicken
What is the key fob problem?
Post #418089 16th Dec 2016 1:13am
Madmutt0
Fib
Hi thanks
Car has been running perfectly then few weeks ago car was left on drive for around a week
Went to get in it and fob would not open the doors
Opened the doors manually gt in and car ran as normal only nokeyfob unlocking
Put a new battery in fob also tried spare key but no remote locking
Also tried a re synce
Checked the fuse14 to the rf reciver no blown and power across the terminals
Bought a second hand rf reciver which I'm fitting Friday
But have read l322 can go into transportation mode but I have everything else working
At a bit of a loss what to try next
Post #418096 16th Dec 2016 7:54am
holidaychicken
Mine has got confused before when i opened with the key, do the doors lock and unlock with the central locking button in the centre of the dash ok ?The light is showing on the keys when you press the button?
Did the rf receiver make any difference ?
Post #418201 16th Dec 2016 9:05pm
jon3929
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Hi, I'd be calling Simon at All Auto's in Weston. 01934 429999 Thumbs Up
I cant recommend anyone in Bristol I'm afraid.
Cheers, Jon.
Post #418236 16th Dec 2016 11:20pm
Madmutt0
Key fob
Hi yes locking works on button
Bought a scanner and no faults are showing on the car
Fitted new /f reciver still no luck
Got up sat morning to take it down to a friend and car won't start dead as a doe doe checked battery and it's showing 11.1 volts
Also now have hove HDR inactive and suspension inactive warnings
Luckily my wife works for fps automotive parts so I have a new battery at 80 pounds
Will be fitting it later
Hope that's the problem
Post #418272 17th Dec 2016 1:02pm
