Home > Maintenance & Mods (L322) > LED main beam headlight bulbs
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
I was wondering whether anyone has any experience with replacing ordinary filament headlight bulbs with an LED equivalent, either in FFRR or anything else I suppose.
Given that LEDs are more efficient than filament bulbs, generating much less heat, I was thinking that an LED equivalent with 55w input would generate a lot of light. As far as I recall, the limiting factor to comply with regulations is the electrical input power, not the amount of light produced. Sure enough, eBay is full of lots of options for not much money, one example below
http://www.ebay.co.uk/itm/110W-20000LM-H7-...3641.l6368
I'm not talking about the D3S HID dipped beam bulbs, which I've recently replaced with cheap Chinese imports which I'm very happy with. This is for the H7 main beam bulb.
Now, I imagine the beam pattern might be very different than an ordinary filament bulb and this may make it a complete non starter. Or, perhaps, the bulb monitoring would throw a fit. Has anyone tried it? Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #418727 19th Dec 2016 11:33pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
ive put a cree in mine but an older version and ok ish but not brill but these look way better imo, i'll order some on pay day friday to give a go _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #418740 20th Dec 2016 1:38am
Eirik34
Norway 2007 Range Rover Vogue SE TDV8 Stornoway Grey
I've upgraded the high beam bulbs with the 2x55w (110W) ZY P6 10400lm H7 Canbus ones (see http://www.fullfatrr.com/forum/topic39089.html). I'm very happy with these - gives a lot more light than the original halogen high beam bulbs. You should try to get a set where the LEDs are places exactly at the same distance from the base as the filament in the halogen lamp, then you get the most correct light characteristic.
Post #418745 20th Dec 2016 9:05am
steveball
Thanks, both, for you experiences. That's helpful to know. The bulbs that seem to work well are about 3x the price of the cheaper ones, so will be interested to hear how you get on Scott. Current: 2010 Range Rover L322
Post #418778 20th Dec 2016 11:54am
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Yep...Watching this closely! Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #418837 20th Dec 2016 5:10pm
this chap on the RRS forum has done it,
http://www.rrsport.co.uk/forum/topic46312.html ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #418839 20th Dec 2016 5:20pm
steveball
Hmmm..... thanks Stan, some interesting and enthusiastic comments there. Starting to make me think that this is worth pursuing. Current: 2010 Range Rover L322
Post #418855 20th Dec 2016 6:14pm
it all depends how much illumination you need...i've tweaked mine up a bit and although they are still 4300k [to be changed soon to 6000k] they do light up the road pretty well... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #418860 20th Dec 2016 6:27pm
