Home > Technical (L322) > TD6 Problems (Update) |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
Yesterday went shopping with the FF. On returning to the car it would not start and in the end had to get recovery out.
28th Dec 2016 3:17pm |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Would have said starter motor or starter solenoid but if you can't turn the key to the start position key and/or ignition lock/switch must be suspect as you have already thought?? Mine was a blue one! |
28th Dec 2016 4:15pm |
Thanks, Andy. Tried everything else so have ordered a switch from Dan. Hopefully that will do it.
29th Dec 2016 2:27pm |
Hello John
29th Dec 2016 3:03pm |
PS
29th Dec 2016 3:07pm |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 138 |
I had this a while back and it turned out to be the ignition lock ECU. There is a thread about it and a link to a pssible solution here:
29th Dec 2016 3:15pm |
Andy, Just down the road Been here full time for 13 years.
29th Dec 2016 4:20pm |
Turned out to be the ignition switch right enough. Replaced and now running. Just got to put the centre console back .
6th Jan 2017 11:16am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
There has been a thread on AULRO in which the switch was removed, contacts cleaned with a good result. Pictures to show how..https://www.aulro.com/afvb/l322-range-rove...tch-2.html 2007 TDV8 VSE
7th Jan 2017 3:46am |
Interesting thread. Will keep the old switch and try cleaning the contacts in case of future need. John
7th Jan 2017 10:21am |
