Home > Technical (L322) > New L322 New Problems! ie no Transmission Range Change |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
If it were a TD6 I would suggest removing the transfer box motor and bench testing it (search for powerfuluk video howto in youtube) - not sure if things are the same with the TDV8?
28th Dec 2016 11:42pm |
Dantnz Member Since: 28 Dec 2016 Location: Isle of Wight Posts: 10 |
That's great info. I'll check that out. I'll do everything else I can before pulling large components though. A diagnostic read out would be pretty helpful to narrow it down too, what's the most basic setup (by which I mean cheapest ) that can read fault codes? Would the ecu need reprogramming after pulling and reinstalling or replacing the drive motor? |
29th Dec 2016 12:00am |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Isn't that the later and cheaper transfer box motor? The one with 4 bolts I think. ECU shouldn't need programming. |
29th Dec 2016 12:40am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
Or perhaps invest in an IIDTool to get the exact error codes. Could be something as simple as a sensor. Got - 2017 SDV8 Autobiography in Loire Blue
29th Dec 2016 12:52am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
If you have a TDV8 with the 6-speed gearbox you have the Magna Steyr DD295 transfer box : http://www.fullfatrr.com/forum/topic12404.html
29th Dec 2016 2:15am |
Phil, thanks for that link, that is an unbelievably helpful post. Really helps to see the components in the 'flesh' rather than just in the manual.
29th Dec 2016 11:41am |
Alan, thanks, I may have to go down this road, was hoping not to have to invest in a code reader, but could save some time narrowing down which component is causing the issue. |
29th Dec 2016 11:43am |
Thanks - on looking through Phil's post on the transfer case, this later unit seems to have the position encoder and drive functions as separate sensors. So I'm guessing if the position sensor needs changing the Case ECU needs to be recalibrated to a new unit but maybe not for a drive motor change. |
29th Dec 2016 11:46am |
