Home > Technical (L322) > Removing ball joint - at wits end
Page 2 of 7 <1234567>
Rewmer
Heat is not a bad idea. The secret is having a high power, oxy acetylene or oxy propane concentrated just on the outer joint. In a short sharp burst it won't have a chance to travel to the hub bearing. The trouble begins if you use a hot air gun or plumbing blow torch over a long period. No7 - 2003 V8 Vogue
Post #419975 29th Dec 2016 12:24pm
holidaychicken
some photos for inspiration
Post #419977 29th Dec 2016 12:33pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Still can't get it off Sad
Going to take it to a mate who's a coach mechanic so hopefully have more luck!
Post #419983 29th Dec 2016 1:23pm
Look like the trick is a big fat cold chisel on the ears of the ball joint, or maybe even your fork splitter Thumbs Up .
Post #419985 29th Dec 2016 1:51pm
holidaychicken
Did you try the sharpened cold chisel, that is what worked for a couple of us, but always easier if you can take it somewhere with better facilities?
Post #419986 29th Dec 2016 1:56pm
Stacker
I haven't yet as I need to at least get the other bolt out first, it I can get that out I don't need to get the arm off the ball joint as they're both getting replaced obviously!
At least I know for the other side that my local Indy can earn some money!!
Post #419998 29th Dec 2016 3:00pm
holidaychicken
Did you try tapping in the next size up torx bit into the bolt ?
Post #420006 29th Dec 2016 3:28pm
Stacker
I did try, it's so seized up it just rounds instantly.
Can't knock the bolt round with a chisel either Sad
Screwed...
Post #420030 29th Dec 2016 5:34pm
Yes torx heads on rusty bolts are a stupid idea!!
Sounds like it will need drilling and tapping. Can you get a grinder in to get the head off it then at least you stand a chance of getting the ball joint out. Once that it done then you might get a stud removed on the exposed end, but apart from that and a lot of penetrating fluid I can't see many other options. There is nothing that can't be fixed with a hammer😜😜
Post #420033 29th Dec 2016 5:51pm
Stacker
That's what I was thinking!
My plan was to grind the heat off the bolt then smash the ball joint through and remove the rest of the bolt with some pliers or something!
Trouble is need to take brake disc off, and the calliper bracket won't come off the hub either Sad
Post #420039 29th Dec 2016 6:09pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
that's why I leave it all to the dealers to sort good luck ! Thumbs Up
Post #420042 29th Dec 2016 6:32pm
Stacker
Got to find a garage that will attempt it now Sad guess I'll be cancelling my trip to Germany on the 8th!
Post #420043 29th Dec 2016 6:39pm
builder1966
had mine done by beadles
Post #420045 29th Dec 2016 6:42pm
holidaychicken
i think you are still in with a chance if you can get a grinder to the heads of the bolts and grind them back until you reach the lugs, then as you say, remove the ball joint using a a chisel and hammering from the top while supporting the hub which should leave a small amount of thread that you can heat the top of and from underneath and a splash of shock and unlock for good measure and then try mole grips on what is left protruding of the thread as i doubt you will get a stud extractor on it or screw a nut on if there if is any thread that is left and weld it to it. In theory once the head of the bolt is gone it is only the rust that is holding it in.
This may depend on getting that bottom ball joint split for access or getting it to a garage while you can still drive it.
Pic below showing the splitter i used
Post #420074 29th Dec 2016 8:54pm
Stacker
It's literally either that or garage, but as I said can't even get the brake caliper bracket off!
16mm bolts, started to round with a 12 point socket so got a 6 point but couldn't get enough leverage, windy gun wouldn't even touch it just vibrated forever and ever and it wasn't any looser Sad
Seriously considering selling the car, can't be dealing with this!
Post #420080 29th Dec 2016 9:25pm
