Home > Technical (L322) > Removing ball joint - at wits end |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Blimey!
30th Dec 2016 12:15am |
And talking of being waded, I present you with a hub nut
30th Dec 2016 12:22am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I edited the post and added a couple of other bits, linking spanners can help.
30th Dec 2016 12:27am |
You could always make yourself some scaffold board ramps, these were for my transmission project.
30th Dec 2016 12:34am |
Holy crap, that is bad, that has been used to wade in salt water by the look of things, heres mine. |
30th Dec 2016 12:55am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7941 |
Stacker, think I'd be looking at a replacement hub and drive shaft, or at least outer CV joint, doesn't look like you have much of the nut left at all....
30th Dec 2016 2:02am |
Thanks for the pictures, I'll see if I can make something up and have another go on Sunday. I might look into getting a dremel as if I can get that in there I wouldn't need to take the brakes off at all, cut the head off the bolt then knock the crap out of the ball joint!
30th Dec 2016 11:42am |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
I really really like this idea!! I presume it's definitely safe to carry the 2.5 ton weight? lol Matt Current 2012 Range Rover 5.0L SC Ultimate Edition 2012 Range Rover 4.4L TDV8 Autobiography 2010 Range Rover 3.6L TDV8 Autobiography 2003 Range Rover 4.4L V8 Bespoke Vehicle Inventor of the retro fit paddle shift and many other modifications. Creator of the custom 2010+ RR MK4 splash screen. Creator of the Range Rover CarPC and lots more! Founder of Range Rover Owner rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos โ YouTube.com/RangeRoverOwner |
30th Dec 2016 7:57pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
Like every job on the Ffat,it is hard work but one thing I have learned with age is spraying up before tackling a job ,either the day before or even better a few times even a week or two before,you will be amazed with the difference. |
30th Dec 2016 9:44pm |
One step closer to heaven baby!! It's out I managed to smash a socket over it!!!
30th Dec 2016 9:54pm |
Bet that was a " yeah!!!! Baby" moment
30th Dec 2016 10:49pm |
Good effort, that's the spirit, these fecking cars are just a massive mind puzzle , I am waiting for my leak down tester to turn up to determine if I need a new engine !
30th Dec 2016 11:23pm |
I was shocked but happy!!
30th Dec 2016 11:26pm |
This is how far I've got today, had to stop now for work
31st Dec 2016 12:37am |
