Home > Technical (L322) > 2 questions
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
2 questions
Hi all,
1st. - Sometimes the light from the transfer box (TT mode) blinks while in movement. I stop, engage N press the button but the light don't goes off and nothing happens (engage) with the trahsfer box. Then I switch the ignition off, start again and the light disapear and if I press the button it works normaly.
2nd - what kind of colling liquid is the best for the TD6?
Cheers
Post #421013 3rd Jan 2017 8:47pm
1st sounds like a failing transfer box motor, do a search, plenty of info.
2nd, From the owners manual.....
Coolant specification
Use ONLY a 50% mix of water and Texaco AFC Coolant. If this is unavailable, use any ethylene glycol based anti-freeze (containing no methanol) with only Silicate based non-phosphate corrosion inhibitors. In an emergency - and only if this type of anti-freeze is unavailable - top-up the cooling system with clean water, but be aware of the resultant reduction in frost protection. DO NOT top-up or refill with conventional anti-freeze formulations. If in doubt consult a Land Rover
dealer.
 Pete
Post #421034 3rd Jan 2017 10:23pm
