Home > Maintenance & Mods (L322) > park brake fault
Harris
United Kingdom 2006 Range Rover Vogue TDV8 Zermatt Silver
park brake fault
Just had new front disks pads and an oil service on my 06 TDV8, and now after driving around 4 miles I get the park brake light (red) flash and the amber brake light flashing. I never normally use the parking brake, only at MOT time and it recently had an MOT as well, any ideas? Also new super heavy duty battery last year.
Post #421599 7th Jan 2017 2:26pm
Baltic Blue
Check if the wheels are hot.
Sounds like park brake could be stuck on. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #421602 7th Jan 2017 2:48pm
Harris
don't think it is stuck on, wheels cool
Post #421604 7th Jan 2017 2:57pm
kbald
Was it only the front pads and discs changed?? There is a hand brake reset procedure butthat's normally done whe. You change the rear discs or epb shoes!
Post #421610 7th Jan 2017 3:25pm
Harris
yes only the front, will talk to the garage monday
Post #421657 7th Jan 2017 8:47pm
Sounds like a front sensor problem then
Post #421661 7th Jan 2017 9:07pm
Harris
interesting, they replaced one front brake wear sensor, how would that show up as a park brake fault?
Post #421664 7th Jan 2017 9:24pm
Faulty sensor, poor connection to the loom, badly fitted to name a few
Post #421678 7th Jan 2017 10:52pm
