Home > Technical (L322) > Stalled after water on road!!! |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Your fault is possibly nothing to do with water, when did you last change the fuel filter? |
5th Jan 2017 12:21pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Today it stalled again.
10th Jan 2017 4:14pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 696 |
Have you changed the fuel pump yet?
10th Jan 2017 5:16pm |
No i di not change yet.
10th Jan 2017 5:25pm |
As the others have said it sounds like your low pressure pump is at fault so the problem will not go away until you change the pump. |
10th Jan 2017 9:33pm |
So not the one in the tank i guess. |
10th Jan 2017 11:09pm |
The pump in the tank was faulty.
11th Jan 2017 8:56pm |
To give some useful info if your car stalls time to tim after some loss of power,in-tank pump faulty not front pump.
12th Jan 2017 2:13pm |
