Home > Technical (L322) > ABS Sensor ? car randomly breaking itself (Issue Fixed) |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
Can i just check cannot find anywhere, Should all the height sensor have the same voltage ?
23rd Dec 2016 2:25pm |
so ordered a Yaw sensor (dynamic stability control ecu) and height sensor !
27th Dec 2016 1:04pm |
Update to this :
20th Jan 2017 3:55pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 |
I've currently got the same problem. The IID tool says it's the front right ABS sensor open circuit. |
18th Feb 2017 3:46pm |
Andy first replace what its says, so ABS Sensor.
18th Feb 2017 4:36pm |
Mine does it from cold. A few minutes after it faults and the brakes lock up, it realised and drives fine. Then when I switch off and leave it for a few minutes and start it up again, it faults again.
18th Feb 2017 5:47pm |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
Just to resurrect this thread, I am having exactly the same issue. Happy all wheel sensors are good and replaced yaw sensor.
30th Jul 2019 12:52pm |
